16" S2 correct tire size
Postby Swerveking » Sat 16.11.2024, 23:02
Hey, I'm upgrading to 16 in S2 wheels on my 91 Fed. What is the std size , and what can I get away with without problems if I chose to go a little wider... So stoked to get this upgrade going! Also, any hot tips on tires? Aggressive street driving is my main focus, don't care too much about rain or snow. Thanks
Swerveking
Re: 16" S2 correct tire size
Postby Fredjohn » Sat 16.11.2024, 23:18
Slight correction....it's spelt tyre :-D :-D :-D
Anyway, see this page on wikilec:
https://web.archive.org/web/20230926212 ... _pressures
The actual tyres stated are no longer available, but the sizes are. There will be as many tyre suggestions as there are tyres available!
Postby Jon » Sun 17.11.2024, 02:45
205/45R16
I've always plumped for the Goodyear Eagle F1s
Jon
Postby dapinky » Sun 17.11.2024, 12:09
The tyre size is the same for the Oz & the BBS wheels in 16" diameter......
...... there is little point in me giving any recommendation as the tires available in USA will be different to those in the UK, Europe or ROW.
But - you are looking for 205/45r16. Wider tyres will fit on the rims, but if you go wider there is every chance that you will scrape the wheelarch liner on full lock. Even if it seems okay with the car sitting still, you may have an issue when cornering and the spring is compressing whilst on lock. It can happen with 205 tyres (tires) if the inflation doesn't match the sidewall flex at the time.
Postby Swerveking » Tue 19.11.2024, 18:14
Thanks for all the good info! I'm gonna probably go with the Toyo Proxxes, It's all about the turns for me plus they look cool!
Swerveking
Postby Hector2021 » Wed 20.11.2024, 17:18
I'm sure you'll be more than happy with Toyo's. I have them on mine and they certainly seem to do a good job of keeping the car on the tarmac. However, my driving style probably isnt quite the same as your 'Aggressive street driving' :wink:
NMY 1995 S2 No:490
Hector2021
Return to Wheels and Tyres
