Head gasket differences - N/A vs Turbo
Postby dapinky » Thu 04.01.2007, 16:38
Hi does anyone know the difference?
As far as the head gasket goes, the part number is different on the N/A & Turbo (6103S & 6104S respectively), but that info is only from the parts manual and I don't know what the actual difference is, or whether it will work with the turbo motor (I presume that it'll probably fit, but I don't know how it will function!).
The reason for asking is that there are some N/A ones in the lotus parts sale, but not Turbo ones.
At £2 a throw is it worth a punt, or money down the drain?
Will it work at all, or just not for very long?
How about limited boost?
I don't want to buy something which aint any good at all, or to spend hours changing/fitting something which won't work, but to maybe keep as an emergency 'spare' could it be worthwhile??
Answers on a postcard please :D
Postby Sy V » Thu 04.01.2007, 16:48
OK, I'll go and buy a postcard...what's your address and are you paying postage?
:wink:
LEC Godfather
Postby dapinky » Thu 04.01.2007, 16:53
Yeah, okay, it's my own fault......... I should have known better :D
[There are far to many facecious gits on here (self included)]
Postby Dico » Fri 05.01.2007, 14:21
Like you said Pinkster, probably aint worth putting all that labour in only to find it don't work :?
And stop being so bleedin tight! must be that Geordie guy you've been mucking around with having an affect on you!
Postby Sy V » Fri 05.01.2007, 14:36
All I was going to offer that the compression ratio on the NA is higher, IIRC.
LEC Godfather
Postby Sy V » Fri 05.01.2007, 14:40
Alternatively, perhaps Lotus gave it a different part number so that when it was included in a head (gasket) set you could differentiate between an NA set (and its contents) vs a turbo set and its specific contents.
Thinking out loud, here.
Bottom line is that I don't really know... :(
LEC Godfather
Re: Head gasket differences - N/A vs Turbo
Postby Specky » Sun 22.02.2009, 14:49
I know this is a bit late, but I now have a new N/A head gasket... I'l take a pic or two sometime
Can some post a pic of an SE gasket please
Postby bobbrown » Sun 22.02.2009, 16:45
What you need is the thickness of them new as probably the rest is the same.
The Natasp has a higher compression ratio but this is normally done with the pistons crown heights.
Bob
Pacific Blue N/A
bobbrown
Postby dapinky » Sun 22.02.2009, 20:24
Specky wrote: I now have a new N/A head gasket...
I do hope you got it from Clemo, and didn't pay top dollar from anywhere else.....
.... I bought up the stock from aftersales 2 years ago, and by the time the 'ordered' ones had gone, the spare couple went down to Torquay for LEC storage :roll:
Postby Specky » Sun 22.02.2009, 20:28
Nope... :(
Lotus Garage... :cry:
SGT 75% 0ff sale.... with a quite a few other N/A bitz.... :-D
Postby dapinky » Sun 22.02.2009, 20:39
Thats okay then........
.....as long as you didn't pay over 2 quid :?
Postby Specky » Sun 22.02.2009, 21:05
I did... :(
£14 squid,
Better than nearly 60 squid thou
