Stock drop-in air filter
Postby lotos » Wed 15.10.2008, 03:49
I am sure this is somewhere around here, but I did searches and couldn't find a complete list.
Looks like the stock replacement filter is available from these manufacturers:
Coopers EG 939
Crossland CF 9164
Fram CA 4744A
Multipart ASU 1816
Unipart GFE 1123
K&N E-2360
Knecht LX706
Again, I'm sure this is redundant, but it may help someone who (like me) couldn't find it through searching. I did find that a lot of the mfr's offer cross-reference part numbers to other brands that are flat out wrong (K&N points to a FRAM filter that's one of the flat panel variety), I think due to a similar model 33-2360. None of my local stores have anything for the Elan, other than the K&N on special order.
lotos
Re: Stock drop-in air filter
Postby Doc Fizzix » Wed 15.10.2008, 04:17
Dam Dude! :D
Will you just buy the Top End Performance set-up and be done with it, it comes with a K&N filter
http://www.racetep.com/lotus.html
:banana:
Doc Fizzix
Postby Doug » Wed 15.10.2008, 07:54
or you can just make up something similar to it on your own
Postby lotos » Wed 15.10.2008, 14:45
Al, your experience with the Mountain chip troubles me a little, because I'd surely rather go that route than a MBC (which puts too much control in my feeble hands). I also never like the idea of putting an air filter where it's sucking in hot underhood air. I know I'm so late to this party that all of this has been discussed ad nauseum years ago...
lotos
Postby Sy V » Wed 15.10.2008, 14:56
Latest Everest chip and K&N 2360
Example Drop in Filter
Postby Doc Fizzix » Thu 16.10.2008, 00:07
lotos wrote:Al, your experience with the Mountain chip troubles me a little, because I'd surely rather go that route than a MBC (which puts too much control in my feeble hands). I also never like the idea of putting an air filter where it's sucking in hot underhood air. I know I'm so late to this party that all of this has been discussed ad nauseum years ago...
I guess everyone is going to have a different opinion on this topic. For myself, I was never able to get the chip to work very well and even after Doug burned me a couple test chips the performance was just not what I was getting with the MBV, not sure if it was an issue with the CA version ECU or just my system. One of the things I like about the MBV is that you are in control of the boost, you can adjust it one way and set it lower or high and then you can come back later and adjust it in the other direction or vis-versa, with the MBV you have the control to change it. With the chip, you get what you order and there is no adjusting, for some this is perfect and makes things very simple but for me I want the ability to control and adjust my boost myself. As for the K&N replacement pipe and filter sucking in hot underhood air that is just simply not a problem or a concern (remember there is an intercooler that all air will pass through), the replacement K&N filter and pipe has a greater exposed surface area with less restriction surrounding the filter that is able to draw in more air with less effort than the original filter and box. Keep in mind that the replacement filter sits on top of the air catch where the original filter sat so it gets a good flow of cold air. The original filter is restricted by the design of the box it is in and the motor has to pull its air through a small opening at the bottom of the filter box and this takes more effort; even though the original filter has a large surface area the air that is drawn into the motor is limited by the hole size in the bottom of the filter box.
I have also had this discussion with nitroman (chip vs MBV) and he might have some more interesting input on this issue.
Doc Fizzix
Postby tweetdriver63 » Thu 16.10.2008, 00:59
As I recall, somebody took temperature readings in different areas under the hood (bonnet), and the temp in the area where the filter is isn't very hot. The area behind the engine/intake plennum is the hot spot. If you find the thread about putting vents in the hood (bonnet), you'll find a link to the one with the temp readings.
You can also confirm this the scientific way. After running at normal operating temp, open the hood and feel the trashcan. It's not particularly hot.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby lotos » Thu 16.10.2008, 01:01
Oh I trust you guys :) Anyone make an intake tube other than Top End?
lotos
Postby Doc Fizzix » Thu 16.10.2008, 01:09
lotos wrote:Oh I trust you guys :) Anyone make an intake tube other than Top End?
lotusgirlmarie
viewtopic.php?f=31&t=10694
Doc Fizzix
Postby tweetdriver63 » Thu 16.10.2008, 01:54
lotusgirlmarie
Isn't Marie's for the other pipe? The one between the intercooler and plennum, with BOV? I think Randy's just asking about the one between the filter and turbo.
Does anybody know if one meant for the Impulse Turbo will fit us?
'91 Elan SE
tweetdriver63
Postby Doc Fizzix » Thu 16.10.2008, 02:28
My bad
You are correct sir, lotusgirl's is the intake to the plum. I think tigerdog previous owner made a very nice intake to the turbo.
Doc Fizzix
Postby nitroman » Thu 16.10.2008, 03:54
Randy, I'm chroming the lower piece & putting Bill's (IsuzuPerformance) chrome intake/BOV on the upper. If that looks nice I'll have no need for the upper pipe/BOV. If you can hang on a month or so I'll sell you the upper with BOV for 1/2 whatever TopEnd is asking.
nitroman
Postby lotos » Thu 16.10.2008, 15:13
Thanks - you've got PM :)
lotos
Postby rip » Thu 16.10.2008, 23:20
Doc Fizzix wrote:My bad
LGM is also currently making a run of trashcan-turbo pipes too.
Postby tweetdriver63 » Thu 16.10.2008, 23:38
lotos wrote:Thanks - you've got PM :)
The first parts store I went to looking for something (blower motor I think), I told the first person at the counter what I needed, and it went like this:
clerk 1: "year?"
me: "1991"
clerk 1: "Make?"
me: "Lotus"
clerk 1 (with odd look on face): "Who makes that?"
me (with that you're a moron look): "Lotus."
clerk 1: "It's not in the computer. Would it be under some other make?"
me (with that you're REALLY a moron look): "No."
clerk 1: "Hey Bubba. You ever heard of a Lotus?"
Bubba (clerk 2): "No. Who makes it?"
me (showing them my backside): "You've got to be kidding...."
Silly me. I thought people who WORKED IN THE AUTOMOTIVE PARTS BUSINESS would have at least HEARD OF LOTUS!!!
'91 Elan SE
tweetdriver63
Postby tigerdog » Thu 16.10.2008, 23:43
Doc Fizzix wrote:I think tigerdog previous owner made a very nice intake to the turbo.
Smaug is equipped with the Top End Performance setup, both the plenum/BOV pipe and the FOAST (filter-on-a-stick). Works well, though I'd prefer a decent airbox to the filter sitting in open under-bonnet. I need to measure ambient temp v. temp near filter in real-world conditions one of these days.
Oh, and if you DO need a BOV to fit the Top-End setup (or any other that uses the TurboXS part, please let me know. I want to replace my "WHOOSH" valve with one ducted back to the intake. I don't like the loud sound, though others like it a lot.
Postby tweetdriver63 » Fri 17.10.2008, 00:39
I found that thread with the temperature readings.
http://forum.lotuselancentral.com/viewtopic.php?f=30&t=12691&hilit=hood+vents
The temp or the air going into the open K&N filter under the hood will be slightly higher than the air coming from the duct into the trashcan. It will also be less restricted, and since it's going into the turbo and through the intercooler before it gets to the engine, I don't think the extra 5 degrees or so will have any impact at all. Also, as somebody already pointed out, since the open filter is sitting right over the opening from the outside air duct, that will make a difference. Brian sampled the temperatures with the trashcan in place and closed. with it removed, the air coming through the duct, that used to go into the trashcan, will cool that area under the hood. I'll bet if somebody took the same kind of readings Brian did, but on a car with the trashcan replaced by the open K&N setup, there would be almost no increased temperature there.
'91 Elan SE
tweetdriver63
Postby Doc Fizzix » Fri 17.10.2008, 01:08
tigerdog wrote: I want to replace my "WHOOSH" valve with one ducted back to the intake. I don't like the loud sound, though others like it a lot.
:lol:
It is always fun the first time you take someone for a ride and they hear that first big "WHOOOSH" :D
They always give you a look and ask the same question "what the heck was that?" :lol:
Doc Fizzix
Postby lotos » Thu 06.11.2008, 23:13
nitroman wrote:Randy, I'm chroming the lower piece & putting Bill's (IsuzuPerformance) chrome intake/BOV on the upper. If that looks nice I'll have no need for the upper pipe/BOV. If you can hang on a month or so I'll sell you the upper with BOV for 1/2 whatever TopEnd is asking.
You still looking to part with it? I saw you said you were having it powdercoated so wondering if your plans had changed on it.
lotos
Postby nitroman » Fri 07.11.2008, 02:37
Yeah I did some photoshopping and liked the body-colored pipes better than chromed, and I couldn't justify coating over the chromed IsuzuPerformance pipe. Wish I could use the BOV from it though; it sounds cool whilst the TurboXS BOV sounds like a person with gas!
nitroman
