Side/Indicator light lenses
Postby djwazza68 » Sun 10.11.2019, 20:32
A long-shot, but I don't suppose anyone has a cross-reference for the side-light/indicator lenses, hopefully from something like a Vauxhall Nova?? I don't fancy the £350 for a new set from SJs, mine were clearly in some sort of altercation that damaged the bumper and were blobbed together with Sikaflex!
djwazza68
Re: Side/Indicator light lenses
Postby dapinky » Sun 10.11.2019, 21:07
Unfortunately, they aren't from a Vauxhall Nova.....
...... however, should your local scrappie have a large selection of Esprits you may find the version with the same light units.
... Sorry, that isn't very helpful - not many Esprits in the local scrappy.........
...still, there is actually a cross reference to another manufacturer which may help......
....if your local scrappy has a selection of McClaren F1's.
(On a sensible note, SW Lotus had them at a cost - and the lenses are available seperately if you can fix your rear shells - lenses as either 2-colour or clear)/
Postby Rambo » Sun 10.11.2019, 21:34
Do you need just the lenses ? Or the housings, gaskets etc as well ?
Postby djwazza68 » Mon 11.11.2019, 00:29
I need just 1 shell as it turns out, I've salvaged 1 from the 3 pieces it was in. The other is beyond help. I will also need the seals for both, they were absent. Can anyone other than SJs or South West help?
I was intending to chrome paint the inside, and wondered what the corroded pieces of aluminium were for?
djwazza68
Postby robertverhey » Mon 11.11.2019, 03:11
Some slightly cheaper options if you search elan m100 indicator on eBay
robertverhey
Postby Rambo » Mon 11.11.2019, 09:42
Cheaper ?? The EBay prices look horrendously expensive to me :shock:
Clear indicators lenses (pair) £79.95 SW Lotus
Clear/amber indicator lenses (3) £79.95
Chrome housing (per item without bulb holders !!) £120 SW Lotus
OEM clear/amber indicator lenses £234 from the States :shock:
Rubber light indicator seal £50 DVB :shock: (you can get these new for about £20 inc vat, p and p from SJS)
If you had to cobble together just the 1 from this list it would cost you an eye watering £250 (without bulb holders) so you're probably better in the long run to go for a pair of new ones at the SJS price you quote above
Postby djwazza68 » Mon 11.11.2019, 10:25
I went the eBay route this morning for a bulb holder for £50 and will get seals from SJs or South West. I should with some judicious use of Chrome paint be fully functioning for less than £100... until something else is discovered to be broken obviously!
djwazza68
