Gear Knob
Gear Knob
Postby Silver Shadow » Tue 13.05.2008, 16:36
I want to change the gear knob since it is very worn out. Can someone please point me out how to do it? Is it by unskrewing? I've tried but I didn't want to force it too much... Thanks
Silver Shadow
Postby F1 LOTUS » Tue 13.05.2008, 16:47
There is a tiny (3mm?) hex screw at the front of the knob that must be unscrewed before you can unscrew the knob.
F1 LOTUS
Postby theelanman » Thu 15.05.2008, 21:29
could you do me a favour?
when you have the original knob off....can you measure the diameter of the gear lever itself.....the size and pitch of the thread and also the length of the thread......on the gear stick bit... :)
cheers
G
Postby Silver Shadow » Fri 16.05.2008, 12:05
No problem. I haven't done it yet but as soon as I do it I will tell you
Silver Shadow
Postby DeeAitch » Fri 16.05.2008, 13:08
IIRC the thread is M10x1.25p. Lever Dia is bigger - probably Dia 12mm but easy to check as the boot just slides down it - I'll nip out and have a look :wink:
Checked and it is 13mm Dia
DeeAitch
