Can't engage reverse (and 4th seems a little tricky...)
Postby frog » Sat 21.10.2006, 10:11
Hi,
I Was getting a sort of 'wheel bearing' noise for a few days, then fourth gear seemed to be tricky to locate - on parking the car, I just couldn't get reverse. What do you think it is? My excellent garage expects it to be a clip that has gone in the gearbox - which makes sense. All other gears seem fine and I can locate 4th without too much trouble - just reverse is totally unavailable.
frog
Postby Monty » Sat 21.10.2006, 11:26
have a look were the cables meet the bracket on the gearbox and see if one of the retaining clips is missing or the plastic part is broken.
Postby frog » Sat 21.10.2006, 18:06
Is it easy to get to?
frog
Postby Monty » Sat 21.10.2006, 19:33
yeah, take of the top pipe going to the throttle body and maybe undo the expansion tank and push it to one side. Then u should beable to see the bracket on the gearbox.
There are pic`s and topic on the forum somewhere.
Postby Candles » Sun 22.10.2006, 17:58
Or just always park where you can drive out forwards.
Candles
Postby frog » Sun 22.10.2006, 22:19
Monty,
Thanks for your useful advice
frog
