by mvf906 » Wed 19.09.2007, 11:12
hi just like to say that the info given to change the gearbox oil was invaluable and my gearbox feels much smoother for doing it.
I managed it in 30 mins with the use of three 10mm extensions with a flex drive on the end (i have a friend that own's a tool shop! ), but i found that a can of Loctite freeze & release was the greatest help not only for the retainer bolt but also the drain plug, which was extremely tight !
hope this helps someone
mvf906
by rip » Wed 19.09.2007, 15:52
mvf906 wrote:hi just like to say that the info given to change the gearbox oil was invaluable and my gearbox feels much smoother for doing it.
Loctite freeze & release.
Positive, noticeable difference.
30 minutes.
Lots of extensions & bits.
Certainly helped me. It has persuaded me to do mine sooner rather than later
by JOSLER » Fri 28.09.2007, 08:08
I think i will have a look at doing mine , thanks for the tips.what oil did you use and how much does it take ?
1991 Calypso Red SE
JOSLER
by Sy V » Fri 28.09.2007, 08:19
32 fl ozs (2 US pints) of
bollocks I've forgotten its name...
Doh
- LEC Godfather
by John_W » Fri 28.09.2007, 08:26
JOSLER,
RedLine MTL" (Manual Transmission Lubricant) is a fully synthetic 70W80 GL-4 gear oil (SAE 5W30/10W30 engine oil viscosity) designed for use in manual transmissions and transaxles. The Transaxle Oil refill capacity is 1.9 US quarts.
See
here.
1.9 US quarts =60.8 fl oz = 3 imperial pints.
- Heid-bummer
by John_W » Fri 28.09.2007, 09:12
Sy V wrote:I stand well and truly corrected.
Sy,
I didn't see your earlier reply (I was still typing), so I didn't mean my reply as a rebuff.
Two bottles, as you say.
- Heid-bummer
by mvf906 » Fri 28.09.2007, 09:13
hi I used two litre bottles (just under) and used Miller TRX fully synthetic oil 80w90
http://www.millersoils.net/1_Millers_fr ... _INDEX.htm
which improved my third gear crunch no end
me in my head, shifting & drifting, mechanical music, adrenaline surge
mvf906
by JOSLER » Fri 28.09.2007, 09:31
Thanks for your help, this is something that i would like to get done before my new baby arrives.
1991 Calypso Red SE
JOSLER
Return to Tools
