Oil filter key
Oil filter key
Postby valimar » Mon 20.10.2008, 19:48
Hi Everybody,
As most of you know changing engine oil is not one of the funniest jobs you can perform on the M100, I hope the following lines will be of some help.
After changing the oil filter several times, using all kind of available keys, I found out the best way to unscrew the filter: I bought one self centering key (see attachment) and with the help of 4 nylon cable ties becomes an easy job to do. Take notice that the bigger cable tie has to be tighten in a way that the key clenches around the filter. If you don’t do this the key will fall and, due to the lack of space, you will not unscrew it easily!
Pay attention: if your arms and hands are close to the gorilla size , just forget the job!
Cheers :mrgreen:
valimar
Re: Oil filter key
Postby ovi » Fri 24.04.2009, 08:01
Thanks! :goodposting:
ovi
Re: Oil filter key
Postby Ellie » Sat 27.06.2009, 04:18
I tried several types and found the 'screw-on clamp' type to be the best at the job and it gives room to get hands in - see attached pictures.
S2 #161 Calypso Red & fun in the sun. S2 means seats two, and I aint walkin'!
Growing old is mandatory; growing up is optional.
Ellie
Re: Oil filter key
Postby valimar » Sat 27.06.2009, 08:14
I have one like that but the problem is you don’t have much room to move the key! Every time you have to unclamp the key and fasten it again to unscrew just a few centimetres of the filter! The one I use now is 1 minute work…
valimar
Re: Oil filter key
Postby rip » Sun 06.09.2009, 15:38
I have a K&N filter on mine now. It can be be removed with a completely different tool...a 25mm spanner!
It is so much easier to manouver into place than any standard filter removal tools. :D
Re: Oil filter key
Postby esprit888 » Sun 06.09.2009, 20:44
Can you share the part number of this K & N filter? :)
rip wrote:I have a K&N filter on mine now. It can be be removed with a completely different tool...a 25mm spanner!
esprit888
Re: Oil filter key
Postby GeoffSmith » Sun 06.09.2009, 22:38
Re: Oil filter key
Postby Monty » Sun 06.09.2009, 23:59
or try one off these
Re: Oil filter key
Postby esprit888 » Mon 07.09.2009, 06:54
Thanks Geoff :D
GeoffSmith wrote:HP1004.
esprit888
Re: Oil filter key
Postby Monty » Mon 07.09.2009, 11:14
Re: Oil filter key
Postby dermotbell » Sun 11.10.2009, 16:49
I got one of those obsolete lotus things that only fits Champion oil filters.
Very happy with it as I can unscrew the filter with just my hand...........until now.
Went to fit new champion oil filter and noticed that they have gone and changed the exterior design, it no longer has the the little indents that the lotus tool was specifically designed to fit!!!! :(
So now back in the hunt for another tool to get the champion off before I fit one of those K&N types.
Dermot Bell
dermotbell
Re: Oil filter key
Postby M100 TWO » Tue 13.10.2009, 18:22
Dermot if you use the Crosland filter No 672 it will fit the Lotus filter key that you have, this filter is what the Lotus garages are now selling at a sensible price.
john
M100 TWO
Return to Tools
