Brit-Car-Nut wrote:If you lowered the car, why not just get 4 planks of 2x8s or so and set them in a way that you can drive on to them and that will give you more distance between the floor and the jacking points. If you need more, add additional pieces of 1x8 thickness?
Putting a slope on the leading edge will make it easy to drive on to them... Not as difficult as driving up onto true ramps.
Elanlover wrote:I don't suppose you have the dimensions you used, do you? Specifically, the length of the bar (as I've had a quick look and noticed that you can't just run a piece from wheel arch to wheel arch due to some contouring under the body) and the spacing of the holes? If not I'll just measure them but thought I'd ask if you had them handy. Thanks!
EDIT: Also, I'm curious to know how much bending the bar does where you put the trolley jack. I ask because, since I've lowered the car, I don't think I can get a 2.x bar under the sills with the semi-low profile trolley jack I have now. So, In either buy new jacks or use a rectangular bar of 2.5x1 or something like that so I can get the jack under it. So I'm wondering if that bar will bend under the load given that it won't be as "thick" as a straight 2x2 bar.
JohnB wrote:Hi.
I'll measure the bars and post them on here.
Elanlover wrote:Brit-Car-Nut wrote:If you lowered the car, why not just get 4 planks of 2x8s or so and set them in a way that you can drive on to them and that will give you more distance between the floor and the jacking points. If you need more, add additional pieces of 1x8 thickness?
I gave that some thought and it might be suitable for some instances. However, I suspect there will be times when the car isn't driveable but still needs to be lifted. Also, my garage is on a bit of an incline and I normally chock all the wheels before lifting with a jack. Not sure I will be able to chock the wheels if they are on 2x8's. So, I'd prefer to have a solution that works for multiple cases but will settle for something like blocks to raise it up first if that's all that will work. Might need thicker than 2x8 as well.
Elanlover wrote:For the record, having gone out and bought some square tube, had it cut, drilled and some washers welded on (wish I had my own drill press and mig welder), this is a fantastic idea. The car is up and seems pretty stable on 4 jack stands. I used slightly thicker walled square tube (.188 inch instead of .125) as I'm a born "over-engineer-er" and I see no deflection in the tube at all when jacking.
Makes for a "relatively" cheap car jacking system instead of buying a $1,000+ hydraulic system to do the same thing that won't likely get quite as high. Simple yet effective - great idea JohnB!
JonJon wrote:I'm guessing this wont work on an S2.
