Latest toy. Excellent Jack
Postby muley » Sat 16.10.2021, 16:09
Best GBP130 ever spent. Transformed my garage projects.
Goes under the car and lifts high enough to put stands under front and rear jacking points
ETA more detail
https://www.halfords.com/tools/garage-w ... SIQAvD_BwE
Re: Latest toy. Excellent Jack
Postby Steve A » Sat 16.10.2021, 17:59
8) Very nice
Postby woody » Sun 17.10.2021, 09:44
Muley,
Where do you place the jack, on your S2, and lift it high enough to fit axle stands under the two front jacking points ?
Regards,
Woody
woody
Postby muley » Sun 17.10.2021, 13:17
Hi Woody
I insert it... ...under THE jacking point. Front only on the S2 :) Then I can put axle stands underneath. One at the front recommended jacking point (2 set screws) and one at the rear (rearmost wishbone mount) All in one lift.
Works a treat
Updating original post with more details
Rgds
Postby dapinky » Sun 17.10.2021, 13:46
I looked at buying that one when I needed a 'good' jack earlier this year - ended up buying a 3-tonne version from SGS.
Main reason being that it had a slightly higher maximum lift (which was needed to get the fuel tank out), but mainly because the 3-tonne limit meant it would be better for use on the VW van.
https://www.sgs-engineering.com/tj3lp-l ... olley-jack
(I got a pair of good ratchet action axle stands at the same time, and they appear to be good quality, like everything else I have got from them)
Postby muley » Sun 17.10.2021, 14:05
Hmmm. The SGS one looks very similar
And cheaper!
Return to Tools
