by paulwatkins » Fri 09.03.2007, 19:12
Has anyone bought a set of 'off-the-shelf' type drive-on ramps for your Elan?
Do they work ok? Or does the front spoiler hit into them?
Has anyone manufactured their own? If so, what pitch did you use so the front spoiler would clear them ok?
Paul
paulwatkins
by Monty » Fri 09.03.2007, 19:23
I`ve used Dico`s Ramps(once) which are from Halfords but had to make an addition to beable to get the M100 up
- Chunder King!
by paulwatkins » Fri 09.03.2007, 21:02
Thanks for the pic Monty.
Was this arrangement ok for clearance?
If it was, I can use the pic to draw up a design on cad for fabrication.
Cheers, Paul
paulwatkins
by Monty » Fri 09.03.2007, 22:24
That was over a year ago but IIRC the clearance was fine and don`t forget pinky has been lowered
- Chunder King!
by ailwyn » Sat 10.03.2007, 12:12
Paul,
Are you planning on getting ramps fabricated?
Might be worth considering whole car ramps if the cost is not prohibitive.
Ailwyn
- Forum Member
by paulwatkins » Sat 10.03.2007, 18:41
Flippin hell!
That is a proper job! However, I'll need something that I can just store away easily when not in use. I dont have the room to leave it out permanently.
Thanks for the info tho Ailwyn.
Paul
paulwatkins
by GeoffSmith » Sat 10.03.2007, 21:50
Paul,
If you made them a bit longer at the front so the C of G went past the apex, you wouldn't even need a jack!
Go for it - I'll buy one in any colour so long as it's not green
Geoff
- Kitty Fiddler
by paulwatkins » Sat 10.03.2007, 21:55
geoffsmith wrote:If you made them a bit longer at the front so the C of G went past the apex, you wouldn't even need a jack!
If it was longer than the car, I'd have to knock the end wall out of my garage to get the ramp in! Be more like a carport then!
paulwatkins
by GeoffSmith » Sat 10.03.2007, 21:59
paulwatkins wrote:geoffsmith wrote:If you made them a bit longer at the front so the C of G went past the apex, you wouldn't even need a jack!
Dual use - charge a premium!
- Kitty Fiddler
by Andy C » Sun 11.03.2007, 10:07
I like the look of this
To gain further unrestricted access to the underside of the car you can remove the lead up units.
Would probably be not to difficult to put together an item that
"uses some of the concepts of this design but is inherently totaly different in it construction"
Andrew
Medina Green #296 Brians Wilwood Brakes, Everest Chip, Piper 2.25, PWR Cooling & ProTech Suspension
Andy C
by dapinky » Sun 11.03.2007, 10:31
I like the idea of removable ramps - both for storage of the items when not in use, and access when in use.
This one looks to have all the strength of a warm Kit-Kat and i would rather see it a bit more solid if i was driving up it, or lying under it!
- LEC Administrator
by Hinch » Sun 23.09.2007, 13:07
Why not buy yourself a good spade for £10 and start digging yourself a nice deep trench? Much easier than all that metal bashing.
Sorry no pictures, use immagination!
Hinch
Hinch
by Dico » Sun 23.09.2007, 17:27
Monty has pictures
The first steps to his double garage, its getting there, slowly.
- Fool Boy Four - Founder
by GeoffSmith » Sun 23.09.2007, 17:33
Dico wrote:Monty has pictures
Water table's a bit low though.
- Kitty Fiddler
by tigerdog » Sun 23.09.2007, 19:04
ailwyn wrote:Paul,
Ailwyn
Ooooh! I'm jealous - I'd love to be able to have this in my garage!
by nitroman » Tue 25.09.2007, 01:27
Order the
Ramp Extension Kit, as they'll work with any existing ramp set you have.
nitroman
by DeanG » Thu 27.09.2007, 23:42
I've used the simple plastic ramps. They only give 5 or 6 inches of lift however they are cheap, easy to store and strong.
DeanG
by rip » Fri 28.09.2007, 00:02
DeanG wrote:I've used the simple plastic ramps. They only give 5 or 6 inches of lift however they are cheap, easy to store and strong.
5 or 6 inches is plenty though. More than enough to get under with a drain tub for an oil change.
by GeoffSmith » Fri 28.09.2007, 09:57
rip wrote:5 or 6 inches is plenty though.
Maybe for you slim, but the typical Elan owner needs a size XXXXXXXL T-shirt.
- Kitty Fiddler
by Russc » Fri 28.09.2007, 12:25
Lol, i use jacks and axle stands and have no real problems.
Russc
Return to Tools
