Drive-on type ramps
Drive-on type ramps
Postby paulwatkins » Fri 09.03.2007, 19:12
Has anyone bought a set of 'off-the-shelf' type drive-on ramps for your Elan?
Do they work ok? Or does the front spoiler hit into them?
Has anyone manufactured their own? If so, what pitch did you use so the front spoiler would clear them ok?
Paul
paulwatkins
Postby Monty » Fri 09.03.2007, 19:23
I`ve used Dico`s Ramps(once) which are from Halfords but had to make an addition to beable to get the M100 up
Postby paulwatkins » Fri 09.03.2007, 21:02
Thanks for the pic Monty.
Was this arrangement ok for clearance?
If it was, I can use the pic to draw up a design on cad for fabrication.
Cheers, Paul
paulwatkins
Postby Monty » Fri 09.03.2007, 22:24
That was over a year ago but IIRC the clearance was fine and don`t forget pinky has been lowered :-D
Postby ailwyn » Sat 10.03.2007, 12:12
Paul,
Are you planning on getting ramps fabricated?
Might be worth considering whole car ramps if the cost is not prohibitive.
Ailwyn
ailwyn
Postby paulwatkins » Sat 10.03.2007, 18:41
Flippin hell! :shock:
That is a proper job! However, I'll need something that I can just store away easily when not in use. I dont have the room to leave it out permanently.
Thanks for the info tho Ailwyn.
Paul
paulwatkins
Postby GeoffSmith » Sat 10.03.2007, 21:50
Paul,
If you made them a bit longer at the front so the C of G went past the apex, you wouldn't even need a jack!
Go for it - I'll buy one in any colour so long as it's not green
Geoff
Postby paulwatkins » Sat 10.03.2007, 21:55
geoffsmith wrote:If you made them a bit longer at the front so the C of G went past the apex, you wouldn't even need a jack!
:-D If it was longer than the car, I'd have to knock the end wall out of my garage to get the ramp in! Be more like a carport then!
paulwatkins
Postby GeoffSmith » Sat 10.03.2007, 21:59
Dual use - charge a premium!
Postby Andy C » Sun 11.03.2007, 10:07
I like the look of this
To gain further unrestricted access to the underside of the car you can remove the lead up units.
Would probably be not to difficult to put together an item that "uses some of the concepts of this design but is inherently totaly different in it construction"
:wink:
Andrew
Medina Green #296 Brians Wilwood Brakes, Everest Chip, Piper 2.25, PWR Cooling & ProTech Suspension
Andy C
Postby dapinky » Sun 11.03.2007, 10:31
I like the idea of removable ramps - both for storage of the items when not in use, and access when in use.
This one looks to have all the strength of a warm Kit-Kat and i would rather see it a bit more solid if i was driving up it, or lying under it!
Postby Hinch » Sun 23.09.2007, 13:07
Why not buy yourself a good spade for £10 and start digging yourself a nice deep trench? Much easier than all that metal bashing.
Sorry no pictures, use immagination!
Hinch
Hinch
Postby Dico » Sun 23.09.2007, 17:27
Monty has pictures ;-)
The first steps to his double garage, its getting there, slowly.
Postby GeoffSmith » Sun 23.09.2007, 17:33
Dico wrote:Monty has pictures ;-)
Water table's a bit low though.
Postby tigerdog » Sun 23.09.2007, 19:04
ailwyn wrote:Paul,
Ailwyn
Ooooh! I'm jealous - I'd love to be able to have this in my garage!
Postby nitroman » Tue 25.09.2007, 01:27
Order the Ramp Extension Kit, as they'll work with any existing ramp set you have.
nitroman
Postby DeanG » Thu 27.09.2007, 23:42
I've used the simple plastic ramps. They only give 5 or 6 inches of lift however they are cheap, easy to store and strong.
DeanG
Postby rip » Fri 28.09.2007, 00:02
DeanG wrote:I've used the simple plastic ramps. They only give 5 or 6 inches of lift however they are cheap, easy to store and strong.
5 or 6 inches is plenty though. More than enough to get under with a drain tub for an oil change.
Postby GeoffSmith » Fri 28.09.2007, 09:57
rip wrote:5 or 6 inches is plenty though.
Maybe for you slim, but the typical Elan owner needs a size XXXXXXXL T-shirt.
Postby Russc » Fri 28.09.2007, 12:25
Lol, i use jacks and axle stands and have no real problems.
Russc
Return to Tools
