This is what has been done to the car since it was purchased a few weeks ago:
Mechanical:
-Spark Plugs and Ignition Wires Changed
-Oil and coolant changed
-New timing belt, alternator and PS/AC Belts
-Lower Temp Fan Switches put in
-New Idler and Tensioner Pulleys
-Right Headlight Rebuilt
-Alloy motor mount bracket (was stripped needed new one put in)
-New water pump (was slightly leaking)
-MAS Sensor Filter (got broken)
-Hub Centric Rings fitted (It was shaking on the freeway without them
now drives smoothly)-New AC Drier fitted and charged with Freeze 12
-Exhauster Hanger (there was one missing and there was a crack that was welded)
Electric/Electronic:
New Stereo (was broken. Fitted it with: Alpine 7949JG competition stereo receiver, Alpine 3553 Amp, 0.5 farret cap, JL Audio 6.5" subwoofer behind passenger seat).
New Battery
Cosmetic:
-Seat adjuster knobs (were missing)
-Leftside Door Cheater Trim (was missing)
-Prop rod retainer (was broken)
-Seatbelt clips (were missing)
-Sun visor (was missing)
-Attached rear view mirror (was in the trunk)
I still need to put in a new A/C clutch, and finish putting the alarm system with proximity sernsors in. Marie is helping me with most of this work and she's doing an amazing job.
Will post more to show progress and improvements! Let me know what you think of the car! Thank you!
