My '91 Lotus Elan M100 Restoration Project
Postby lotuselanman » Sat 23.07.2011, 03:09
Hello Everybody! As you might have read by now I am new to Lotus' and have recently purchased a Lotus Elan M100. I am currently getting it to a good and reliable stage and wanted to show and tell you guys the work that has been done. These are pictures of the car before any work was done and I will post the pictures of work being done along the way and after it is finished:
This is what has been done to the car since it was purchased a few weeks ago:
Mechanical:
-Spark Plugs and Ignition Wires Changed
-Oil and coolant changed
-New timing belt, alternator and PS/AC Belts
-Lower Temp Fan Switches put in
-New Idler and Tensioner Pulleys
-Right Headlight Rebuilt
-Alloy motor mount bracket (was stripped needed new one put in)
-New water pump (was slightly leaking)
-MAS Sensor Filter (got broken)
-Hub Centric Rings fitted (It was shaking on the freeway without them ;-) now drives smoothly)
-New AC Drier fitted and charged with Freeze 12
-Exhauster Hanger (there was one missing and there was a crack that was welded)
Electric/Electronic:
New Stereo (was broken. Fitted it with: Alpine 7949JG competition stereo receiver, Alpine 3553 Amp, 0.5 farret cap, JL Audio 6.5" subwoofer behind passenger seat).
New Battery
Cosmetic:
-Seat adjuster knobs (were missing)
-Leftside Door Cheater Trim (was missing)
-Prop rod retainer (was broken)
-Seatbelt clips (were missing)
-Sun visor (was missing)
-Attached rear view mirror (was in the trunk)
I still need to put in a new A/C clutch, and finish putting the alarm system with proximity sernsors in. Marie is helping me with most of this work and she's doing an amazing job.
Will post more to show progress and improvements! Let me know what you think of the car! Thank you!
The second small hairline crack on the front bumper
The rear end looks nice. The exhaust is not stock, I had it welded as there was a crack and a hanger was put in that was missing. It is really loud as it is an aftermarket exhaust with the silencer removed (I think).
The bottom of the front bumper is a bit chipped although this does not bother me too much. The side flasher lights were the opposite of where they were supposed to be but this has been flipped around...
The top was in good knick but the seals need to be replaced.
The interior looks a lot better in the pictures than it does in real life. I really hate the cheap vinyl they have used inside and wish that it had the original leather although the seat frames are original. The original leather made it a lot more lower when you sat down, this is a bit too high for me... (5'11") When I have the money in the future I will get them reapullstered.
The engine bay looked clean enough but needed the water pump and all the belts changed. The oil and spark plugs hadn't been changed in a year either.
The rims are a bit too blingy for my taste and are really cheaply manufacutred 17" EEs (made in China unfortuantely). I will get the original rims or upgraded O.Z. 17" ones when I have the money.
Close up of the interior. The speedo is not working, fuel (petrol) gauge seems not to be correct, oil pressure and boost gauges not working. Shifter knob is an aftermarket Sparco and the shifter has been sawed down to about half the length to make a short shifter.
The front end is beautiful, and paint overall is nice and feels rather fresh!
President of the Golden Gate Lotus Club
www.gglotus.org
Photographer/Filmmaker/Writer
www.silverchroma.com
91' Fed M100
lotuselanman
Re: My '91 Lotus Elan M100 Restoration Project
Postby tigerdog » Sat 23.07.2011, 15:26
Excellent work! Car looks good and will only get better, I'm sure.
Postby lotuselanman » Sun 24.07.2011, 00:50
Thank you tigerdog! Here are some pictures of improvements that have been done to the car:
Welding the exhaust which had a small crack in it.
(393 KiB) Not downloaded yet
Creating a short shifter by sawing the shifter in half :-), this is called working on a budget, but actually it worked brilliantly! Much nicer to shift!
(450.31 KiB) Not downloaded yet
Belts, spark plugs, ignition wires, etc... being changed, complete overhaul! :-)
(483.83 KiB) Not downloaded yet
www.gglotus.org
91' Fed M100
lotuselanman
Postby lotusgirlmarie » Wed 27.07.2011, 18:21
The fun never stops. So many nic nacky bits to take care of. Still a lot to do to get to snuff.
Leak in the vacuum section of the heater controls (it's not the lines. It's in the controls)
AC compressor clutch does not engage (did a quick test and the solenoid is dead or stuck)
Drivers side power door lock knackered
Pass side window is off track
CDL not engaging properly (DS DL the culprit)
Boost gauge knackered (case and face are split apart)
Oil pressure gauge knackered (face and case spilt apart. Tested wires with new gauge and wires tested good)
Been slowly getting everything working again. Been a job so far. She is coming back to life though and is a strong runner with most the mechanics now sorted.
lotusgirlmarie
Goddess
Postby steve matthews » Wed 27.07.2011, 23:24
Are those cigars in your map pocket :?:
steve matthews
Postby lotuselanman » Thu 28.07.2011, 03:26
steve matthews wrote:Are those cigars in your map pocket :?:
No it was actually the caps for the wheels. They are now on the car... Also got some hub centric rings fitted which helped a lot with stability. Will need to get an alignments once everything is done before I go to LA.
Thanks Marie, you are doing a great job and I really appreciate it! Runs like a champ and hopefully once the other gremlins are sorted everything will work as it should! :-)
www.gglotus.org
91' Fed M100
lotuselanman
Postby tigerdog » Thu 28.07.2011, 04:05
lotusgirlmarie wrote:Boost gauge knackered (case and face are split apart)
There's always the cheapie VDO/photopaper face trick. I have printed a bunch of spares of my latest. Add one to a VDO 150121 Turbo Gauge and use your old lens and bezel. I am afraid I can't help with the oil pressure gauge. Interestingly, though, the dead gauge from which I salvaged my lens and bezel was also cracked in exactly the same way. Another US West Coast car. What gives?
Postby lotuselanman » Thu 28.07.2011, 05:01
Oh it's ok, I've already ordered the gauges from aftersales. Good to know though for the future!
www.gglotus.org
91' Fed M100
lotuselanman
Postby lotuselanman » Sun 28.08.2011, 00:43
Some updates of more things has been done on top of what was already mentioned:
-Spark Plugs changed again due to fowling from improper spacing and use of non OEM sparkplugs.
-Fixed Doorlocks (and found the missing rod in the actual door).
-Fixed both windows (Butterfly clip and gliding clip were broken on passenger side door), both windows had problems opening and closing but now work well.
-Installed used Speedometer gauge and new oil pressure and boost gauges.
-Alligned headlamps with spacers
-Plastic square covers put in holes in the door panels where they used to be.
-Mounted amplifier in trunk
--Installed trunk (bonnet) release motor (with a Saab push button release behind the drivers seat when key is in the ignition and a remote release on the alarm remote when outside).
Still to do:
Fix lock on glove box (lock and pin fell out, put back in but problems alligning).
Figure out why engine fans are not working, car overheated on the freeway stop n go traffic 100* outside (Check relays, fuses, and finally replace Thermostat and maybe lower temp fan switches(again) if it's not electrical).
Install Doorlock Plungers and ashtray and swap out speedometer which I am borrowing for the one I bought and install new seat adjuster knob with proper washers.
Photo's and more updates to follow!
www.gglotus.org
91' Fed M100
lotuselanman
Postby lotuselanman » Sun 28.08.2011, 01:24
Maybe it's the heat that cracks them ;-). It's been over 100 everyday since I got to LA... not used to it being from San Francisco and all... I park under a tree thankfully so the sun doesn't damage the paint or vinyl/leather inside...
www.gglotus.org
91' Fed M100
lotuselanman
Postby Lotus54 » Sat 15.10.2011, 21:52
I need to replace my receiver drier (but will stay with the 134).
Do you have a part number?
Mark
Lotus54
