Central Lock
Central Lock
Postby Marc333 » Mon 30.07.2007, 12:39
Hi!
My Elan have not a remote control central lock.I can build the transmitter and the receiver,but i don't' know when i connect the receiver.Anyone can help me? Thank you!
Marc333
Postby nitroman » Mon 30.07.2007, 14:32
Depends on whether you're in the USA or elsewhere. The CDL control unit is above the glovebox in USA models; not sure of the location on non-USA cars.
nitroman
Postby Marc333 » Mon 30.07.2007, 15:40
nitroman wrote:Depends on whether you're in the USA or elsewhere. The CDL control unit is above the glovebox in USA models; not sure of the location on non-USA cars.
I am in Italy. M.
Marc333
Postby evert » Tue 14.08.2007, 14:05
Marc,
it is not as simple as you might expect. I used the transmitter&receiver from my car alarm. The CDL unit uses two lines which have to be disconnected or one end switched to ground (as far as I remember) to make it work. If you want I can look up the schematics I used (about two years agoo).
evert
Postby addict » Tue 27.05.2008, 21:57
im in the same boat however in my case the whole central locking module is missing.
addict
