Yella Fella
Re: Yella Fella
Postby GeoffSmith » Mon 30.03.2009, 22:03
Doug wrote:(he's still installing the hood scoop, lambo doors, and fat can exhaust pipe)
Careful, you'll put him in hospital!
Re: Yella Fella
Postby nitroman » Tue 31.03.2009, 02:07
tigerdog wrote:Very well done! Two questions: how do you like the low-beams? And don't your high-beams feel incredibly wimpy now? :)
The car's still up on ramps, but I'll give you an answer in a few days. I measured the gap on each adjustment screw before I took the lamp assy apart, and reassembled accordingly, so very little aiming should be required.
nitroman
Re: Yella Fella
Postby nitroman » Wed 01.04.2009, 06:34
1/8" flat Al bracket to ensure that the plastic piece cannot warp. Warpage causes the majority of oil leaks here as the rubber O-ring then becomes canted within the channel, pulling it progressively out of contact.
nitroman
Re: Yella Fella
Postby nitroman » Wed 01.04.2009, 07:46
General statement here: I had not intended to replace many of my coolant hoses this week, but am noticing how even hoses on a seldom used car (16k) are nearly dryrotted. Obviously we've not had reports of people being stranded with burst hoses, but it is still bothersome to think about on any car still with the original hoses. I hope to stop short of replacing the BIG hoses this week! I actually am at a logical 'hose' stopping point now, but???
nitroman
Re: Yella Fella
Postby Monty » Wed 01.04.2009, 11:42
Matt, engine looks as clean as ever. Thats a good simple solution to the stupid plastic cover for the cam oil seal :smt023
Re: Yella Fella
Postby nitroman » Sat 04.04.2009, 08:49
Which spark plug cover, silver, black or yellow?
IMG_1194 (Small).JPG (64.33 KiB) Viewed 6544 times
IMG_1193 (Small).JPG (62.45 KiB) Viewed 6542 times
IMG_1192 (Small).JPG (63.94 KiB) Viewed 6544 times
nitroman
Re: Yella Fella
Postby RichardK » Sat 04.04.2009, 08:51
Easy one - Black!
RichardK
Re: Yella Fella
Postby nitroman » Sat 04.04.2009, 08:53
For now I switched back to a black blow-by cover with the silver spark cover.
The lower-temp (165F) thermostat works great with the low-temp (the lowest of the two Dickman switches) fan-switch. The fans come on at just under 1/4 and turn off very shortly afterwards. The temp stays right in the middle of the 0 - 1/4 range.
IMG_1198 (Small).JPG (68.94 KiB) Viewed 6539 times
IMG_1197 (Small).JPG (66.84 KiB) Viewed 6539 times
IMG_1196 (Small).JPG (58.07 KiB) Viewed 6541 times
nitroman
Re: Yella Fella
Postby GeoffSmith » Sat 04.04.2009, 09:57
RichardK wrote:Easy one - Black!
Re: Yella Fella
Postby Specky » Sat 04.04.2009, 11:21
The contrast thing works...either silver or black... Silver for me...
I think you've got a bit of corrosion there :shock: .... on the "O" in Lotus :poke:
Re: Yella Fella
Postby GeoffSmith » Sat 04.04.2009, 12:05
nitroman wrote:The lower-temp (165F) thermostat works great
:shock: Surely you mean 180°F Matt.
Re: Yella Fella
Postby tigerdog » Sat 04.04.2009, 14:43
Silver +1
With the silver wires, BOV, etc. it just looks right. Nice job!
Re: Yella Fella
Postby lotos » Sat 04.04.2009, 16:04
Wow, stunning. Thanks for the pics!
:smt038 :smt038 :smt038 :smt038 :smt038 :smt038 :smt038 :smt038 :smt038 :smt038 :smt038 :smt038 :smt038
Anything but yellow for the plug cover... Maybe I'll take that off your hands and we can see how it looks on a stock-color engine.
lotos
Re: Yella Fella
Postby nitroman » Sat 04.04.2009, 20:43
Specky wrote:The contrast thing works...either silver or black... Silver for me...
Actually I freshly polished the 'O' but not the other letters (yet)!
nitroman
Re: Yella Fella
Postby lotos » Sat 04.04.2009, 22:39
nitroman wrote:For now I switched back to a black blow-by cover with the silver spark cover.
What is the blow-by cover?
lotos
Re: Yella Fella
Postby nitroman » Sun 05.04.2009, 09:34
It's the cover on the little 'box' which the fuel vapors from the engine (there's a port in the cam cover) are scrubbed of oil before being routed back into the intake tract. In my 1st three pictures it has a yellow cover on it, afterwards a black cover.
BTW I'm leaving on Tues for surgery and probably won't back until the weekend.
nitroman
Re: Yella Fella
Postby lotos » Sun 05.04.2009, 16:27
Ahh, I see it, thanks!
Good luck on Tuesday - I'm sure things will go well. Stay strong - the community needs you!
lotos
Re: Yella Fella
Postby max and andy » Mon 06.04.2009, 00:57
Nitroman are the pipes the same as the ones Marie is doing the group buy with. Just painted with calliper paint instead of polishing. Max & Andy
max and andy
Re: Yella Fella
Postby lotos » Mon 06.04.2009, 01:01
Nope - they're from an outfit here in the states called Top End: http://racetep.com/lotus.html Their pipe utilizes a TurboXS brand blow-off valve, whereas LGM's is made for a GReddy BOV.
lotos
Re: Yella Fella
Postby max and andy » Mon 06.04.2009, 01:07
I mean did he paint them and did they start off the same material as Marie's?
max and andy
