Doug wrote:IMHO there's no engine worth doing cause don't forget you'd have to fit it to the tranny or somehow get another tranny to fit--this would mess up the axles and bring on the torque steer, etc, etc
it'll never happen if his car is an Elan
stroke it, bore it, build it, and force-feed it -- certainly you could get whatever HP numbers you want fron it if built right
surferphil wrote:I think it's the unique Lotus engineered suspention geometry and the fact that there are equil length drive shafts that stops the torque steer.
geoffsmith wrote:If you start altering the balance of the car by throwing away a load of weight in the front, I would imagine the handing is going to degrade and the "fastest point to point" claim will only hold on a straight road! Not really what the Elan is all about. Also, you will get even less traction without the extra weight of the engine so, apart from the engineering challenge, I can't see the point in trying to change the engine.
geoffsmith wrote: Costas has demonstrated there is plenty of potential for overcoming the extra weight.
If nursey could hold off the medication for a while, perhaps DaveT could enlighten us as to the intended use.
PS How the hell did you know Doug?
Paul.P wrote:Dico wrote:4 wheel drive, if you're going to do it, do it proper
Not in an Elan you won't, Costas looked at doing it !
surferphil wrote:Paul.P wrote:Dico wrote:4 wheel drive, if you're going to do it, do it proper
I read that Lotus fully intended to do a 4WD M100!?
surferphil wrote:geoffsmith wrote:If you start altering the balance of the car by throwing away a load of weight in the front, I would imagine the handing is going to degrade and the "fastest point to point" claim will only hold on a straight road! Not really what the Elan is all about. Also, you will get even less traction without the extra weight of the engine so, apart from the engineering challenge, I can't see the point in trying to change the engine.
Sorry Geoff, that makes no sense to me. You loose weight at the front and loose weight at the back - the car is balanced.
The car isn't brilliant at handling due to a heavy old engine. It handles well because the chassis holds and the suspension works. I can't see how a lighter car will handle worse!?? What you wrote goes against the very fabric of what Lotus is about?
Loose weight and you don't need so much traction to accelerate or corner. If you want more traction, then use the air flow to give down force. Loose the weight and gain performance.
Lighter better point to point!
Monty wrote:You have to remember it's a front wheel drive, less weight at the front will make it more difficult to get the power down. But would imagine this could be solved by the suspension set up.![]()
IMHO
Engine is up to the job
loss some weight
and concentrate on the suspension side of things, brakes, wheels and tyres.
Once the handling is up to the job then think about a turbo upgrade
Paul.P wrote:surferphil wrote:Paul.P wrote:Dico wrote:4 wheel drive, if you're going to do it, do it proper
Would be very surprised Phil, theve not exactly got a lot of experience in that field ?
geoffsmith wrote:The suspension was designed (very well) around the weight and weight distribution the car has. Start changing that and the characteristics will change; eventually, you will reach a point where you would need to alter the suspension etc. Although we've got a lot of expertise on LEC, nobody has anywhere near the experience or facilities that Lotus had to develop the Elan, so I don't think anyone can say where that point is.
FWD is inherently bad at getting power down because the front tends to lift (i.e. become lighter). RWD is far better because the rear tends to squat down (i.e become heavier). The force you've got between the wheels and the road, the more grip you've got and the more power you can get down.
Users browsing this forum: AhrefsBot and 1 guest
