Project Challenge/Competition
Postby nitroman » Thu 21.02.2008, 21:39
surferphil wrote:
nitroman wrote:Gents, if you've thought about the packaging realities you know there's no space to run a drive-belt for driving a supercharger without cutting a hole through the top of the bonnet... wanted to be sure you have that reality in mind.
This kind of comment is why I have not published my Red Rum Restoration and 'Fast Cat' projects, it just makes forum discussions a painful waste of time! :roll:
Phil, if you can figure out how to route the supercharger belt without modifying the bonnet then more power to you. (no pun intended)
nitroman
Postby GeoffSmith » Thu 21.02.2008, 21:51
How are the projects going? One dual purpose prototype complete (apart from R2)! :-D
Postby DeeAitch » Fri 22.02.2008, 17:37
Geoff, I'm getting a warm cheeky feeling :lol:
Does this comp. have to be a kit or will a set of instructions suffice?
Here's my 2008 entry:
1. Find an old Volvo in local scrappy
2. Remove seat heater elements with the help of Mr Stanley (Watch out for the angry man and his dog)
3. Fit them to your Elan seats - strong finger nails required.
4. Wire in via a 10 amp fused relay from spare fuse in footwell and one of these:
5. Enjoy!
BTW I nominate ESM for a lifetime achievement award!
(85.02 KiB) Downloaded 49 times
DeeAitch
Postby ESM » Sat 23.02.2008, 14:25
A lifetime achievement award :shock:
I must be looking as if I'm ready to pop my clogs :(
ESM
Postby paulwatkins » Mon 25.02.2008, 21:01
I was thinking about developing a modification to automatically lower/raise the side window whenever the door is opened/closed.
This would allow the seals to be re-manufactured out of a much more robust and firmer material, with a more defined groove so that the window can raise into it forming a better seal.
I have seen this applied to other cars; I'm sure it can be adapted to suit the Elan.
Any volunteers to take on the seal development? Thats not my field I'm afraid. I've got a set of a-pillar and some over-door seals to use as basic templates!
paulwatkins
Postby Doug » Mon 25.02.2008, 21:07
how about an airbag suspension, so when you park you can slam it to the ground :-D
Re: Project Challenge/Competition
Postby Dico » Wed 27.02.2008, 22:21
Sump guard
ailwyn wrote:
It's no good just coming up with an idea
Can't here youoooo :twisted:
Postby PAUL30 » Thu 28.02.2008, 14:23
[quote="paulwatkins"]I was thinking about developing a modification to automatically lower/raise the side window whenever the door is opened/closed.
This one would get my vote! :D
PAUL30
Postby DeeAitch » Thu 28.02.2008, 14:37
As this is becoming a wish list:
ABS please :P
Dico, How much would a sump guard be worth? :-D
DeeAitch
Postby Sy V » Thu 28.02.2008, 14:45
I've said this before, but my blue scrapper had a sump guard on it. It bolted into the two redundant holes on the lower block, front left as you look at the engine.
Would be a piece of cake to replicate... for someone of the metal bashing/welding ilk.
Postby theelanman » Thu 28.02.2008, 15:08
paulwatkins wrote:Any volunteers to take on the seal development? Thats not my field I'm afraid. I've got a set of a-pillar and some over-door seals to use as basic templates!
Paul
me possibly......
initially Im getting a 3d surface scan done of the A post seals....
Im then gonna get a dye done for it and then play with materials....
or probably send the scan to a seal manufacturer and see what he can do...my first choice is the hollow rubber but we will see
Im also planning on modeling what I think it should be and getting that made up......once Ive done that I'll see which one works :-)
cheers
G
ps Im deff interested in the window drop idea.....you'll be getting an A+ from me when you get it perfected:-)
Postby Rogerf » Thu 28.02.2008, 19:35
Go for it G,
i think it would become the largest group buy ever!! :D
Roger
Rogerf
Postby Doug » Thu 28.02.2008, 19:58
Postby Dico » Fri 29.02.2008, 13:44
A cup of McDonalds finest :P
Postby GeoffSmith » Sat 01.03.2008, 17:26
Progress report:
CheapScan™: prototype built and trialled successfully in the car today. I reduced the size and weight to the bare minimum so it easily fits in the door pockets or glovebox without getting in the way, but always available to diagnose fault codes when you least expect them.
ElanFan™: I have changed tack and have a cunning plan to use the coolant temperature sender output to start the fans; this is on the right side of the thermostat and will require the minimum of buggeration.
ElannyFanny™: More test devices procured and ready to try out. Good job Summer's coming and people in cold climes no longer need their fannies (US definition of course) warmed.
One more I might tackle - FBT drier. Mine are fogged up having been in the garage for two months. I'm thinking either a dessicator or to pipe heat from the air vents through the gauges or to give them a little heater of their own. :smt017
Mr Itch, you do realise that Dico's already fitted a sump guard.......
Postby Dico » Sat 01.03.2008, 18:14
:-D That 'Trial' one was binned quite a while back.
Postby Rodman » Sat 01.03.2008, 19:18
PAUL30 wrote:
paulwatkins wrote:I was thinking about developing a modification to automatically lower/raise the side window whenever the door is opened/closed.
This also gets my vote. :D
Rodman
Postby Monty » Sat 01.03.2008, 21:55
[quote="geoffsmith"]Progress report:
quote]
i`ve not been keeping up with this thread but like the sound of the Cheapscan
A) it`s got cheap in it`s title
B) Be good for loging runs whilst i`m out on track :wink:
Postby GeoffSmith » Sat 01.03.2008, 22:32
Monty wrote:B) Be good for loging runs whilst i'm out on track :wink:
No! That would be the datalogger that is on hold due to lack of interest. :?
Postby dapinky » Sun 02.03.2008, 11:12
geoffsmith wrote:No! That would be the datalogger that is on hold due to lack of interest. :?
Oi!
It seemed to be you who assumed there was no interest :?
I've always wanted a 'black box' flight recorder!!!!
