How do you want your lights? - Back panel Mod
Postby surfboardfiller » Fri 23.02.2007, 17:32
redvette6327 wrote:I'd be on board for a 2 piece design similar to Roger's. The elise lights are my preference. I assume this design would fit US models. I love the "Shark" 1-piece design but I imagine our plates would not fit.
No problem! :-D
surfboardfiller
Postby Darren » Fri 23.02.2007, 17:45
I'd be in for either the 2 piece design (like Rogers) or a 1 piece, adjustable design like the Shark, adjustable as no two Elans are alike.
Eitherway, Elise rear lights are a must :wink:
Darren.
Open mouth, insert foot.
Darren
Postby Monty » Fri 23.02.2007, 19:24
Phil, if i was u i wouldn`t get involved with the fed spec as there spoiler is different which IIRC which means there eyebrows are different and that was one of the reason LGM was asking for UK spec eyebrows. Think LGM will be doing the Fed type :?
BTW have u worked out how to get round the number plate lights?
Postby surfboardfiller » Fri 23.02.2007, 20:44
Monty wrote:Phil, if i was u i wouldn't get involved with the fed spec as there spoiler is different which IIRC which means there eyebrows are different and that was one of the reason LGM was asking for UK spec eyebrows. Think LGM will be doing the Fed type :?
I have come up with a flexible system to manufacture the back panel, allowing a wide range of light sizes to be used and updated.
There are no eyebrows for this panel. I consider them a fix or an adapter to get the stock Alpine lights to fit an Elan body.
If Marie has the Fed spec covered, then I shall leave it up to her, but I can taylor this product to a custom design.
If you like your reg plate plinth there is no reason you should have to change it: e.g. I can easily make the panel without the plinth section.
I like to be dynamic with my work. :-D
New reg plate light options are 2 strait bulbs or strip of LEDs (£20 each) lit from the top. :wink: Watch this space
surfboardfiller
Postby Monty » Fri 23.02.2007, 23:17
surferphil wrote:New reg plate light options are 2 strait bulbs or strip of LEDs (£20 each) lit from the top. :wink: Watch this space
Kool :-D
Just going back to the fed option, was just worried if u didn`t know the differences (as if I do :? ) just sounds like u`ll have to make 2 different patterns :? Think Maries option is the 2 separate light units so the Fedral guys may still be up for the one piece option.
Are u any good with a spary gun LOL :-D
Postby surfboardfiller » Sat 24.02.2007, 13:42
Kool :-D
Just going back to the fed option, was just worried if u didn't know the differences (as if I do :? ) just sounds like u'll have to make 2 different patterns :? Think Maries option is the 2 separate light units so the Fedral guys may still be up for the one piece option.
Not too bad with a spraygun! LOL! I no longer have access to one so I use someone else who has a garage and spray kit, he's also cheaper than me! LOL so I'll probably get him to prime the panels and B-Post caps and maybe do a few of the common colours to keep the cost down for the guys buying these panels. :D
surfboardfiller
Postby dapinky » Sat 24.02.2007, 13:53
surferphil wrote: I'll probably get him to prime the panels and B-Post caps and maybe do a few of the common colours to keep the cost down for the guys buying these panels. :D
To keep MY costs down even more.....I've got a compressor and a couple of spray guns :lol:
Postby GeoffSmith » Sat 24.02.2007, 13:54
Phil,
Whatever you do, get your angles right, so the water doesn't puddle behind the number plate.
Geoff
Postby petestubbs » Sat 24.02.2007, 16:24
Hey guys,
I've only just got around to reading this post,
I too feel that the Elan looks 'aged' from the rear and would love a set of these lights, I'm not fussy any of the options would suit me as long as they are not too expensive, any idea what we are looking at as a guestimate of price?
petestubbs
Postby surfboardfiller » Sat 24.02.2007, 17:46
Fantastic! do you have a spray room too? :wink:
surfboardfiller
Postby surfboardfiller » Sat 24.02.2007, 17:47
geoffsmith wrote:Phil,
Geoff
They will be spot on Geoff 8)
surfboardfiller
Postby dapinky » Sat 24.02.2007, 20:43
surferphil wrote:Fantastic! do you have a spray room too? :wink:
I just use the garage, sheeted up with polythene and a couple of halogen I/R heaters!
Postby surfboardfiller » Sun 25.02.2007, 23:49
8)
OK!
I really need some volunteers please, to buy their lights so I can make fittings for them and make sure everything has been allowed for before I design the mould. Only one of each type of course.
No lights will be harmed during the making of this product. :D
So far the contenders are:
Elise Series 1 (Bulbs)
Elise Late - LEDs (Resistor pack required)
Hella LEDs (comes with resistor packs)
Bova Coach Lights (Bulbs)
and possibly generic (cheap) Kit Car lights
Please put you protests and support forward now as the model needs to be finished this week.
Cheers,
surfboardfiller
Postby davidjt » Mon 26.02.2007, 21:13
Happy to fork out for some early Elise lights; before I do, can you confirm that they will be either recessed slightly, or flush with the panel?
Don't really fancy a bug-eyed rear end.
davidjt
Postby DeeAitch » Mon 26.02.2007, 22:01
surferphil wrote:I really need some volunteers please, to buy their lights so I can make fittings for them and make sure everything has been allowed for
Try Ghengis79 - he just paid £345 + P&P for a full set http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=017
on fleabay :evil:
DeeAitch
Postby surfboardfiller » Mon 26.02.2007, 23:53
davidjt wrote:Happy to fork out for some early Elise lights; before I do, can you confirm that they will be either recessed slightly, or flush with the panel?
Yes, recessed more at the bottom, not much at the top.
No obligation to buy the panel.
If you (or anyone) don't like the pannel for some little niggle, then I can customise the panel to your requirements at a minimal cost.
I'll pay postage :D
Cheers David!
surfboardfiller
Postby surfboardfiller » Tue 27.02.2007, 00:04
on fleabay :evil:
I think he saved himself about £90! Not cheap, it's a shame this seller had only one set :roll:
surfboardfiller
Postby surfboardfiller » Thu 01.03.2007, 13:06
Elise Series 1 (Bulbs) - Davidjt
Elise Late - LEDs (Resistor pack required) - Ailwyn
Hella LEDs (comes with resistor packs) -
Bova Coach Lights (Bulbs) -
and possibly generic (cheap) Kit Car lights -
surfboardfiller
Postby Kevin » Fri 09.03.2007, 19:37
Darren wrote:I'd be in for either the 2 piece design (like Rogers) or a 1 piece, adjustable design like the Shark, adjustable as no two Elans are alike.
Darren.
Same here!
As long as i can put the original lichts back, so easy montage.
Kevin
Postby ailwyn » Fri 09.03.2007, 19:49
Phil,
Any work in progress pics?
Ailwyn
