by Specky » Thu 13.01.2011, 13:25
I've decided on a new project....
Power steering Pump overhaul.
I Just fancy doing it for Shits and giggles.
A couple of questions:-
Anyone done it?
Does anyone have an old pump they don't require anymore.
I'm looking for a freebie that I could have, this way I can carry out the task and it doesn't matter if it all turns to shite.
by Specky » Thu 13.01.2011, 17:09
Don't use these numbers as I'm just putting them here as part of the project.
GATES Part # 348415 Power Steering Repair Kit
EDELMANN Part # 8833 Power Steering Repair Kit
ACDELCO Part # 36348415 SEAL KIT,P/S PUMP -; PUMP SEAL KIT
GM No 19185878
http://www.gmpartsgiant.com/components/ ... 1rf77.html
by tigerdog » Sun 16.01.2011, 18:05
you really don't have enough to do, Specky. Perhaps you'd like to come over and install my PS rack?
by Specky » Sun 16.01.2011, 20:16
I've got an afternoon free next Tuesday if you want to bring Smaug over.....
by steve matthews » Sun 16.01.2011, 21:19
Specky wrote:I've got an afternoon free next Tuesday if you want to bring Smaug over.....
Tigerdog
If you go by the way of Japan count me in.
Steve wanting to visit DR.LOTUS Japan.
steve matthews
by lotusgirlmarie » Mon 17.01.2011, 03:46
After a bad run of luck a few years back I had to replace the rack on my Elan. Took me all if 12 hours to do as some of the fittings are a pain to get to. Would probably take me less now that I have a better sense of what needs to happen.
The pump as per Isuzu is not a serviceable item. That just sucks.
lotusgirlmarie
- Goddess
by tigerdog » Wed 19.01.2011, 04:44
Sorry! I'm stuck in Stockholm at the moment and couldn't fit Smaug into my carry-on.
by texas2201 » Thu 20.01.2011, 21:44
I've got a spare old pump and found a company in London that would refurb it for £120 plus postage
Power steering specialist
unit 1 brocklebank ind est
charlton
london se7 7sx
fax 0208 858 7595
www.powersteeringspecialist.co.ukhowever if you want to have a crack at it I could drop it over to you with the seats and trim?
Martin
"brakes are no good - they just slow you down" Fangio
by Specky » Thu 20.01.2011, 23:25
IIRC 12 dollars for a seal/ rebuild kit.
Just under a 100 dollars for a non OEM pump, not confirmed and I guess I never will.
by texas2201 » Fri 21.01.2011, 00:40
Specky wrote:IIRC 12 dollars for a seal/ rebuild kit.
by Specky » Fri 21.01.2011, 01:02
This is the project I'm working on, well when I get a pump...
viewtopic.php?f=80&t=18487&p=242283#p242018TTFN
by texas2201 » Fri 21.01.2011, 19:17
Still puzzled - I have an old pump that you could use as an experiment
by bobbrown » Fri 21.01.2011, 23:51
Talking to your self?
Pacific Blue N/A
by Specky » Sat 22.01.2011, 00:51
It's either that.... or carryout a headgasket change.
And I can't be arsed...
