Availability of grommet around the air intake pipe
Postby Paul.P » Mon 29.01.2007, 22:14
As a matter of interest, i was told this is the same grommit that is used around the petrol filler pipe.
Postby paulwatkins » Mon 29.01.2007, 22:19
Me too please Dave!
1. Ray D ?
2. Dapinky
3. Dave big Ed
4. Christy
5. mickmick
6. Clown feet
7. notright
8. Elvis
9. Sheprob
10. Dico
11. paulwatkins
paulwatkins
Postby Paul.P » Mon 29.01.2007, 22:22
dapinky wrote:Another group buy coming on? :bonk: :banghead: :bonk: :banghead: :bonk: :banghead: :bonk: :banghead:
Must say Dave, for someone who's only been with us for 4 mnths, your doing rather well ! :lol: , is it another hobby of yours ? :wink:
Postby Dico » Mon 29.01.2007, 22:26
When are you starting the rear caliper group buy from the stated Dave?
:shock: :P
Postby Paul.P » Mon 29.01.2007, 22:29
Think Dico means the states Dave, it ok, ive got used to the northern lingo, & how to read it :lol:
Availability of grommet around air intake pipe
Postby algirdas » Mon 29.01.2007, 23:31
Dear Dave:
Please put me down for two of the grommets.
Sincerely,
Algirdas
Noli illegitemi carborundum.
algirdas
Postby ailwyn » Mon 29.01.2007, 23:56
1. Ray D ?
2. Dapinky
3. Dave big Ed
4. Christy
5. mickmick
6. Clown feet
7. notright
8. Elvis
9. Sheprob
10. Dico
11. paulwatkins
12. Algirdas x 2
13. Ailwyn
:wink:
Postby Rogerf » Tue 30.01.2007, 00:10
Can you please add me to the list!
Roger
Rogerf
Postby ailwyn » Tue 30.01.2007, 00:12
1. Ray D ?
2. Dapinky
3. Dave big Ed
4. Christy
5. mickmick
6. Clown feet
7. notright
8. Elvis
9. Sheprob
10. Dico
11. paulwatkins
12. Algirdas
13. Algirdas
14. Ailwyn
15. roger_fewtrell
Postby theelanman » Tue 30.01.2007, 00:24
1. Ray D ?
2. Dapinky
3. Dave big Ed
4. Christy
5. mickmick
6. Clown feet
7. notright
8. Elvis
9. Sheprob
10. Dico
11. paulwatkins
12. Algirdas
13. Algirdas
14. Ailwyn
15. roger_fewtrell
16. theelanman
Postby Doug » Tue 30.01.2007, 02:52
Maybe Darren can make one out of CF?
or Brian can CNC an Aluminum one, with a LEC logo on it ??? :-D
Postby DeeAitch » Tue 30.01.2007, 09:35
I bought one of these when I first got my car as the split OE one bugged me every time I opened the bonnet. However I refused to fit it and gave it to someone on here, I forget who :oops:
Perhaps they could post pics before you all jump in. The OE is 3 times the price but IMHO is thin for a reason.
DeeAitch
Postby mickmick » Tue 30.01.2007, 11:58
as we are all talking bout the same thing i'll add a question/problem
the pipe in my car that goes thru said rather tatty grommit, whats it supposed to be attached to, cos mine is "floating" and tends to "clunk" when i drive around/change gear etc etc
mick
now i have one, i just want to keep tinkering with it!!!!!!!
sorry mum :(
mickmick
Postby ailwyn » Tue 30.01.2007, 13:33
Mick,
Are you talking about the pipe that runs from the plenum to the intercooler?
Ailwyn
Stolen from Neil's thread
engine bay.jpg (47.21 KiB) Viewed 6059 times
Postby mickmick » Tue 30.01.2007, 15:35
yes, thats exactly the one.
should it be conected to anything inside the front wing??
sorry mum :(
mickmick
Postby dapinky » Tue 30.01.2007, 15:57
Mick,
Yep. :-D
Basically, the air flow runs something like this:-
Atmospheric air (1 bar) goes through the air filter dustbin & along the corrugated hose to the Turbo.
Passing through the turbo it is pressurised to ~1.6 bar, and goes back through the lower pipe (sort of parallel to the corrugated one) and out of sight to the intercooler.
The intercooler is like a radiator / oil cooler thingy with the big hose going into it one end.
As the pressurised air goes through the radiator, it is cooled by airflow (like coolant in the normal radiator), and becomes more dense.
At the other end of the intercooler, it goes into the metal hose which comes back out through the wing (with a nice new grommet!). It then goes through the last big bore rubber (or stainless, or carbon fibre) hose (the one where you fit a ‘dump’ valve – if you have one) to the throttle body where it mixes with petrol and into the engine (simplified version!).
As such, the metal pipe should be attached to the outlet from the intercooler radiator. If it isn’t you’ll have no turbo advantage as the engine is only sucking in atmospheric air!!!!!
Postby mickmick » Tue 30.01.2007, 16:35
soooooooooo
if my tube isnt conected to anything it might be why i dont seem to have as much power as i expect to have and also maybe why my guage only reads to 0.5ish usually
sounds like i'm gonna have to get my wheel arch liner off (after 16 years thats gonna be fun to try)
mick
sorry mum :(
mickmick
Postby DeeAitch » Tue 30.01.2007, 17:45
This pipe also has a bracket behind said wheel arch liner which bolts to the chassis. As for getting the liner off good luck :P and - shameless punt here- you may like to have a look at my post for new fasteners as I have a load left :cry:
DeeAitch
Postby Enright » Tue 30.01.2007, 17:51
There may be a slightly easier way (although I'd advocate freeing up any siezed nuts anyway - you never know when you might really need to gain access). And nice new shiny fasteners are always satisfying!
If you can completely block the lower big hose that goes from the turbo to the intercooler, and remove the top big hose the goes from the metal pipe into the throttle body, then you could pressure test it.
You would do this by trying to blow down it like a trumpet (but without the silly noise - you'll look quite silly enough blowing down your hoses as it is)! :P
Honestly, that's what I would do.
If it's all properly sealed then you'll be able to feel pressure building up.
If it's not, then you'll hear it hissing and can trace the leak.
Postby mickmick » Tue 30.01.2007, 18:19
well, i think there's def something wrong, as, even after i made sure my timing was spot on, sorted out the high revs problem, i went for a couple of runs to check the performance of the car and found out my 0-60 tims are about 10 seconds and my 0-100 times about 22 seconds
i def got a problem somewhere, meant to be a sports car ffs
sorry mum :(
mickmick
