Trying to get more members signed up for this as Bob Brown sent me an emailing asking if we can get more owners on board the cheaper he can get the hubs made up.
This conversion will replace the one piece hub & disc to a seperate hub and a seperate one piece disc. So in the future when the disc have to be replaced thats all you need to change which will only cost you approx £20 to £30 the pair instead of the £140 + bearings.
You can still use the stock rear caliper as normal or if you`ve got the Hi-spec/wilwood fronts then you may like to go for BB`s Rear Hi-spec brake conversion (see Suspension and Brakes section)
Here`s the link to the Rear Hub conversion discussion thread,
viewtopic.php?f=41&t=12665
Jay
bobbrown wrote:I have had a quote to get the hubs machined and it comes in at £102.37 each hub for 20 off 10 axle sets
Now if we can get to 20 axle sets (40hubs) total the cost comes down to £89.69 each hub and no doubt if there are more then the price will come down even further.
There is one other cost to add in and that is delivery and I may be able to get them delivered in pairs direct or even if they are all sent here the one off delivery cost for the whole lot is not likely to add too much + delivery to you say £6.00
If any one is thinking I will wait for the second run then beware the cost is related to numbers and if only 10 people are interested on the second run the price will be higher!
I will list the other parts that are required to use the standard/ Dorman caliper shortly once I had a chance to look them up.
Also I will need your money before I place the order as it is a lot of money when you multiply it up.
Put your name on the list below if only you are absolutely sure (this is not a maybe list!)
