ailwyn wrote:The ignition should be on (lights on dash) or the engine running before you hit "start talking".
After you've pressed F1, you can change the acquisition and update periods (the former is how frequently ElanScan asks the car for data and the latter is how often the display is updated) - change them both to e.g. 2000ms which will then churn out data every 2 seconds which gives you a chance to see what is happening. I will be more concerned if the returned bytes are inconsistent so no need to let me know exactly what is being displayed, but it would be good to get an idea as to how inconsistent they are. ailwyn wrote:If you have turned the ignition on, make sure you've not activated the immobiliser as that can cut power to the ECU, so for initial testing start the engine before connecting.
ailwyn wrote:Second thing is are you sure you have a working ALDL cable? Can you test it on another car with another PC?
Not with the serial interface, because it's open collector output and relies on the ECU pull up resistor to give a high level.ESM wrote:The interface should give an echo even if its connected only to the PC and not to the car.
geoffsmith wrote:Oliver,
Alan and Nige have cannot confirm that it works with the N/A so I have e-mailed Clemo.
Watch this space before buying a new ECU!
Geoff
