PAS system fluid?
Drivetrain problems
PAS system fluid?
Postby paulwatkins » Mon 15.01.2007, 08:38
Hi guys,
A straight forward question......
What products are you using in your power assisted steering system?
Cheers, Paul
paulwatkins
Postby M100 TWO » Mon 15.01.2007, 09:47
Dexron 2 auto trans fluid
M100 TWO
Postby paulwatkins » Mon 15.01.2007, 09:53
Do you go for a particular brand? Or is that not important?
Cheers, Paul
paulwatkins
Postby M100 TWO » Mon 15.01.2007, 09:54
Castrol
M100 TWO
Postby paulwatkins » Tue 16.01.2007, 12:51
Thanks for the information, I'll use that when I refill the system.
Cheers, Paul
paulwatkins
