How do you want your lights? - Back panel Mod
Postby F1 LOTUS » Fri 09.03.2007, 21:13
Elise lights?
F1 LOTUS
Postby GeoffSmith » Fri 09.03.2007, 21:19
F1 LOTUS wrote:Elise lights?
No. Just a big purple rectangle!
Postby dapinky » Fri 09.03.2007, 21:27
There are a few on flea-bay at the moment (none of the LED ones though).
I'm bidding on these ones.
Postby Monty » Fri 09.03.2007, 22:18
Hey Phil,
Will you have a prototype ready for Donny?
Postby F1 LOTUS » Sat 10.03.2007, 02:37
dapinky wrote:There are a few on flea-bay at the moment (none of the LED ones though).
Good find - Good luck :D
F1 LOTUS
Postby surfboardfiller » Sat 10.03.2007, 16:41
I'll post some model pics on monday, I got 3 of the 4 LED lights from Lotus, enough to build a mould for them, and make a panel for you. The last LED pod should arrive next week.
They look awesome by the way!
surfboardfiller
Postby surfboardfiller » Sat 10.03.2007, 16:46
Monty wrote:Hey Phil,
Yes, I hope to have one on the back of Ailwyns car! 8)
surfboardfiller
Postby ailwyn » Sat 10.03.2007, 17:02
8) 8) 8) :-D
ailwyn
Postby Monty » Sat 10.03.2007, 21:32
8) 8) 8) :-D
You lucky sod :wink:
I`ll have a screw driver out in the car park :-D
Postby GeoffSmith » Sat 10.03.2007, 21:48
8) 8) 8) :-D
Has it got a drain hole to let the water out? :twisted:
Postby surfboardfiller » Sat 10.03.2007, 22:04
Psycho Smith, I like to see the problem as the water getting in rather than how to get it out; which is why I am making the panel from a waterproof material.
Yes, I appreciate I've broken with Lotus' tradition, but I will design one which will leak and steam up no matter how much silicone and gaffer tape you use, just for the enthusiasts! :-D
surfboardfiller
Postby GeoffSmith » Sat 10.03.2007, 22:16
surferphil wrote:Psycho Smith, I like to see the problem as the water getting in rather than how to get it out; which is why I am making the panel from a waterproof material.
:asleep: Wake up Phil! I was thinking more about the water in Ailwyn's footwell when he gives it some welly! :smt043
Postby ailwyn » Sat 10.03.2007, 22:16
Phil,
I think that Geoff is on about the pool in my passenger footwell rather than any issues with your panel.
Never mind, he'll find something else to harp on about sometime :D
A.
ailwyn
Postby surfboardfiller » Sun 11.03.2007, 00:02
Geoff never stops thinking about Ailwyns footwell!? :roll: :offtopic:
Can i point out Mr Sniff that you quoted a conversation about the panel on the thread about the panel did you not.
Yes, I got it, was I too subtle? I'll be a bit less so, see if you get it :evil:
Maybe you prefer to start your own thread: Ailwyn's 'leakage problems' :&uckoffyouDrwhohairedmidgetbastrd:
:smt043
surfboardfiller
Postby GeoffSmith » Sun 11.03.2007, 00:19
Phil, I was behind a Smart car yesterday (but not for long) and it seemed to have a set of small round lights. It might be worth having a look if you haven't already.
Must go - Atomic Rooster have just come on Pandora!
Geoff
Postby Dico » Sun 11.03.2007, 09:30
surferphil wrote: Mr Sniff
:smt038
Postby surfboardfiller » Fri 16.03.2007, 18:23
Ok I can't get these ready in time, I have a problem with the moulding material I'll have to work out next week! :roll: Sorry Ailwyn.
All the Led lights have now arrived (and they look fantastic!). So there is no real problem in getting these made, just a delay. :cry:
see yall tomorrow,
phil
surfboardfiller
Postby Enright » Sat 17.03.2007, 02:26
Looking very nice, but before you reach the point of no return and cut the holes, just a word about spacing:
Costas got it just about spot on. IMHO every other rear panel I've seen has spaced the lights too far apart. It makes them look a bit wierd.
I can measure the diameter, spacing and distance from the centre-line on Elises and Esprits at the show tomorrow and post the results if you like.
Postby DeeAitch » Sat 17.03.2007, 15:15
Very critical with the Elise light cluster which are a tad too small IMHO but the best option we have. Maybe Costas can supply the spoacing on his?
I'm sure I'm too late with this :oops: but just in case :wink: it might be worth considering some 'styling' lines to break up the surface - something like Lotus F1 & Marie posted on the USA ones? That would give those with light body colours the option of painting in a contrasting colour to break up the expanse of body colour on the already bulbous :oops: rear end
Not really a problem on Black 8) as Costas has shown.
DeeAitch
Postby F1 LOTUS » Sat 17.03.2007, 17:40
Or...you [I] could do a few layouts in Photoshop with different spacing and positioning?
F1 LOTUS
