by Monty » Sun 22.04.2007, 16:21
Dico wrote:Monty wrote:How old are the spark plugs?
errrr where did u get that quot from
you causing trouble
Nissias
Paulwatkins had his injectors tested and seviced by a specalist, not sure if this was the place but there some vids on there on testing.
www.pineport.co.uk/p_injector_servicing.html
- Chunder King!
by nissias » Sun 22.04.2007, 20:24
I am in cyprus mate.
I will find someone to test my injectors though. possibly if 1 or 2 of them are leaking I will just change all of them with new. Anyone can suggest an alternative brand than the expensive stock ones? Is it easy to find similar ones?
nissias
by Specky » Sun 22.04.2007, 21:01
Had to read the quote...
I understand you're proud to be Greek...
Whilst on the sublect of testing injectors.. is there an easy way...
I have access to an ultra sonic bath.. it would be the testing I would stuggle with..
by nissias » Mon 23.04.2007, 06:44
i now know what i have to do. I just have to find a place here in Cyprus where they will test my injectors
so if they are leaking I think the only way to solve everything is to just replace them as I doubt they can be reconditioned or fixed.
nissias
by GeoffSmith » Mon 23.04.2007, 07:14
If you believe it's the injectors, then swap 1 and 3 with 2 and 4 to confirm.
- Kitty Fiddler
by nissias » Mon 23.04.2007, 08:00
geoffsmith wrote:If you believe it's the injectors, then swap 1 and 3 with 2 and 4 to confirm.
probably we should try and clean them first, then test them, and if they are still leaking then replace them with new ones
nissias
Users browsing this forum: lotustonybassplayer and 6 guests
