paulrwebster wrote:On of the bolts has dropped out of my hood, I am having problems screwing it back in again. Is there any way that I can release the tension that the hood is under to help me get everything lined up? Do I need to take out any of the other bolts first before I can get the missing one back in?
Dave_Speck wrote:paulrwebster wrote:On of the bolts has dropped out of my hood, I am having problems screwing it back in again. Is there any way that I can release the tension that the hood is under to help me get everything lined up? Do I need to take out any of the other bolts first before I can get the missing one back in?
Mine did this... check for a geometric lock on the seal frame right above the driver’s window..It’s ok to raise the hood to a mid position to get access... but double check for geometric locks before you close it again.
It should screw in easily with no pressure on the hood and assisting the arm that's dropped.
Or the other way... man up... eat three shredded wheat... and push up the arm that's dropped...both ways work.. I prefer this one..
paulrwebster wrote:CanI clarify, is a geometric lock a hinging joint, like your kneecap?
paulrwebster wrote:If so, do you just bend it to release the pressure or do you take the bolt out?
markv wrote:I have the same problem with my hood, but the bolt has sheared in my case. Can anyone recommend where I can buy one, as they look quite specialised.
