Russc wrote:So, in reality, as long as i remove the FCD and MBC and put it through the BSV (abreviation city!!) then i should be ok and it's not likely to explode on me.
In a nutshell, exactly!
I agree with Neil. Obviously check for leaks, disconnected or perished hoses etc while you're in there.Russc wrote:Then i can get it to a R.Road and get it set up nicely.
you'll see a red and black hose coming out, the black hose is the one that should go to the BSV (which would normally be mounted on the air-box shelf), then from the BSV it disappears down towards the radiator, heading in the direction of the oil cooler (i.e. runs from the LH to RH side) but I lose it where it runs under the intake in your picture.
Enright13 wrote:But this is how yours needs to be set up:
