Can I make Elan M100 to adopt 4X114.3 rims?
Postby kmckmc » Fri 08.06.2007, 14:52
Hi,
I have fitted Brian's Wilwood conversion. It has a HAT, which is to be attached to the roter/disc. I was wondering if I could make the HAT to accept 4X114.3 rims. Is it a simple task just to drill additional 4 holes to the HAT?
And if I were to drill additional 4 holes to the OE rear roter/disc, it can also adopt 4X114.3 rims, right?
Am I on the right track? I found several rims with Offset +55 which are 4X114.3.
Elan M100 S2
kmckmc
Postby Monty » Fri 08.06.2007, 15:09
Nope :roll:
the hub is still 4 x 100 PCD, u can`t change this unless u replace the whole hub assembly.
Micheal, there`s no way of getting round it. U need
7" wide rims (205 tyre)
4 stud 100 PCD
56.6 hub center
offset from 48mm to 60mm
Like i`ve said before have a look at the BMW Mini wheels
Postby kmckmc » Fri 08.06.2007, 15:54
Hi Monty,
Thanks for your comment.
I am just trying all the possibilities.
Elan M100 S2
kmckmc
Postby johnny » Sun 10.06.2007, 10:57
[quote="Monty"]Nope :roll:
Like i've said before have a look at the BMW Mini wheels[/quote
Wheelbase have em, 500 with tyres
Hey- there's only on f in Geof Smith.. U crack me up. Poor old Dad..
johnny
Return to Wheels and Tyres
