by geez » Mon 18.06.2007, 04:50
What is the ideal tyre PSI for a 1991 Lotus Elan SE turbo please?
geez
by Ultimatt » Mon 18.06.2007, 19:39
It can depend upon the tyre and ambient temperature in my experience, but the standard is 26.5.
You may want to try slightly harder and softer pressures either side of this to get the best handling feel for you.
Hope that helps.
Matt
M100 Elan SE:
Metallic Gold Fleck Red.
Carbon intake pipes.
Bailey recirculating BOV.
Samco hose kit.
Pro-tech shocks.
S2 wheels.
16" Wilwood Brake upgrade.
S/S Exhaust system.
Everest Chip !
Ultimatt
by geez » Tue 19.06.2007, 08:14
cheers, 35 a bit high then!
geez
by ailwyn » Tue 19.06.2007, 08:17
I run mine at 30, don't know how much of a difference 16" S2s will make
ailwyn
- Forum Member
by John_W » Tue 19.06.2007, 12:46
Geez,
It all depends what tyres you have.
The standard pressures for the original-spec Michelin MXX's for the SE were 28.5 psi alll round. When Michelin stopped making the MXX's and Lotus OK'd the Pilots for the Elan, the technical bulletin stated pressures should be 30 psi all round (I presume it would have had something to do with the reduced sidewall stiffness of the Pilots, but don't know).
If you have any tyres fitted apart from those two, you'll have to play around to find the optimum pressures, using the standard recommendations as a starting point.
This has been asked before (for a 1990 SE, not '91, but they're identical):
see here.
Also see
here for more discussion.
- Heid-bummer
by geez » Wed 20.06.2007, 05:22
Ok thanks mate - good info
geez
Return to Wheels and Tyres
