by TrueBlue » Wed 11.07.2007, 18:51
got my elan yesterday
the front lights are not flush with the bonet and raised slightly in a few corners
is this because of the MOT adjustment they may have made
is there a remedy?
i'm not a mechanic but could do with some advice about what will be expected to be done to sort out this problem if it can be sorted in any way
many thanks for help here
TrueBlue
by Doug » Thu 12.07.2007, 04:33
some better replies will likely follow
there are adjustable stops along the sides of the bonnet -- perhaps you can adjust the edge of the bonnet up to match the lights
or you could adjust the front edge of the light lid down by adjusting the lifter arm's length
likely it will take a picture of the front of you car posted here to get the right help
- LEC Founder
by gtm100 » Thu 12.07.2007, 12:18
Can't see your reg no in your avatar, I assume you have the later type pods, mine are the early "opera glass" folding type so the adjustment will be diferent.
Adjust the bonnet stop to match the bonnet to the wing and front top shell.
Add/take away shims to the rear mounting of the pod to get the rear alignment and the same at the front. The adjuster rod has a positive stop at one end of it's movement and a microswitch at the other on mine.
gtm100
- Tinkerer
by GeoffSmith » Thu 12.07.2007, 20:26
I think it's more serious than the lights - there are a couple of other threads on this
here and
here!
- Kitty Fiddler
by GeoffSmith » Thu 12.07.2007, 20:30
- Kitty Fiddler
