HI
I have just splashed out on this 92 SE, I dont know one end of an engine bay to another. Here is a pic any advice would be helpful.
I think there are a few projects I would like to get done, I think first off I may look at chiping her and then she really needs a brake upgrade.
Bits that have been done include
She is a 1992 on a k and has had alot of work done to her including
New clutch, including flywheel, bearings and oil seals
New sump,
Cam belt and belt adjuster.
Injector flush with fuel additive.
Water pump,
New custom built radiator,
New coolant circulation pump,
Torquemaster turbo sparkplugs,
New high performance HT leads,
New battery,
S2 type hood,
Larger later s2 allys,
HKS turbo dump valve & steel inlet conversion pipe,
K&N inlet filter.
Exhaust is a big bore peco stainless system.
Turbo XS adjustable boost valve
Not sure what some of these upgarde do but make her go QUICK.
Any thoughts?
