by ailwyn » Fri 20.07.2007, 21:33
ailwyn wrote:and have an RS232 to BT adaptor that can transmit/receive on the RS232 line at the correct baud for the ECU and send the data via bluetooth at 9600, 14.4k or other commonly supported BT rate.
Doesn't even need to be that clever, I have a BT to RS232 converter, so it would just need an RS232 serial out (usual 9 pin D connector) from a PIC at a common baud rate.
If anyone fancies prototyping it, it can be easily tested.
A.
ailwyn
- Forum Member
by GeoffSmith » Fri 20.07.2007, 21:40
Babel fish required!
Are we talking
PIC microcontrollers or
Personal Internet Communicators "internet access for people in emerging countries..." like Wales.
- Kitty Fiddler
by ailwyn » Fri 20.07.2007, 21:47
Whichever does the job for the least amount of cash
A.
ailwyn
- Forum Member
by lotuska » Fri 20.07.2007, 22:52
I'm using a PIC microcontroller.
lotuska
by GeoffSmith » Fri 20.07.2007, 22:59
So you haven't got a BT to RS232 converter!
At least we know what we're talking about, even if no-one else does Mark. I'd be interested in hearing what you're up to, but no hurry as we're off on holiday on Wednesday.
Geoff
- Kitty Fiddler
by ailwyn » Sat 21.07.2007, 11:23
geoffsmith wrote:So you haven't got a BT to RS232 converter!
Is it just the Welsh dialect you can't understand??
I thought that what I'd written was fairly straightforward? Maybe not.
ailwyn
- Forum Member
by GeoffSmith » Sat 21.07.2007, 14:22
- Kitty Fiddler
by ailwyn » Sun 22.07.2007, 12:04
So, now that's been clarified, back to my original question.
Can one of you harware guys come up with a black box that will act as a relay/translator/repeater (or whatever description will make Geoff happy) between a PC's 9-pin serial port and the ALDL interface, operating at 9.6k or 14.4k between the box and PC and at the correct baud from the box to the ECU?
Ailwyn
ailwyn
- Forum Member
Return to ElanScan
