by Joe » Sun 23.09.2007, 19:46
I'm sure some of you remeber me posting about my boost gauge reading low (0.3bar max). I was told quite rightly to not worry about it as the gauge is bad. But I've always felt that it lacks zing as it seems GTi 16v quick and not at all what I was expecting from an elan.
My elanscan cable arrived and I've just had chance to figure out how to assemble and use it and low and behold max boost on elanscan was 0.3 bar. (running on shell superunleaded full throttle and max revs in the first three gears along a runway)
Where next? I'm a total Elanscan numpty at the moment so what should I be plotting to diagnose the problem. I'm sure the waste-gate is functioning as I can hear it chitter through the K&N when upshifting at full chat.
Joe
by paza1 » Sun 23.09.2007, 19:52
Hi Joe,
Post up a zipped Elanscan log file. I am sure someone will take a look at it for you.
Good luck
Mark
Silver 1992 SE Turbo.
paza1
by Joe » Sun 23.09.2007, 20:08
paza1 wrote:Hi Joe,
Good luck
Mark
Good plan. Will do
Joe
by John_W » Sun 23.09.2007, 20:57
Joe,
One possibility is that it sounds like the BSV is not cutting in. Check that it's still there (underneath the air cleaner) and still connected. A previous owner may have disconnected or even removed it to put a MBC on, then removed the MBC for sale without reconnecting the BSV.
- Heid-bummer
by carryondentist » Mon 24.09.2007, 19:03
check your throttle cable is tight too - and really giving you 100% open throttle.
carryondentist
- Tinkerer
by GeoffSmith » Mon 24.09.2007, 22:16
Post the ElanScan log Joe!
- Kitty Fiddler
by Joe » Mon 01.10.2007, 18:38
I've not forgotten, Elanscan log coming up soon. (when I get back from IOM) I'm working away for weeks on end at the mo which is why my posting is sporadic
Joe
by Joe » Fri 12.10.2007, 23:06
Shame less bump. My Laptop battey is rogered so I need to liberate a Fag lighter plug equiped inverter from work to sort the elan scan issue sorted by the end of the weekend
Joe
