has this manifold had it`s day ??
Postby Russc » Sat 06.10.2007, 15:27
As i`m sure you can all tell with other posts from me i`m not exactly an expert in these things and it`s years since i`ve pulled a car apart.
But in porting the wastegate i`ve dragged the manifold off but i`ve found a couple of cracks.
Wasn`t blowing before i took it off but as it`s such a sod to get off and on again is it just a matter of time before it dies??
Or are these repairable??
bigger piccie of the left hand crack
Russc
Postby Specky » Sat 06.10.2007, 16:58
Is that a crack at the one o'clock as well...
Postby GeoffSmith » Sat 06.10.2007, 17:02
How successful are cast iron repairs these days Dave?
Postby Specky » Sat 06.10.2007, 17:29
geoffsmith wrote:How successful are cast iron repairs these days Dave?
I wouldn't mind getting my hands on that manifold, just to see how bad those cracks are... NDT head on again...
Personally I Wouldn't repair or refit it...
It looks buggered...
Postby Russc » Sat 06.10.2007, 18:41
I had a feeling that was going to be the conclusion :cry: :cry: especially when i posted the piccie, does look bad.
And yes there is another one at 1 o'clock
Russc
Postby GeoffSmith » Sat 06.10.2007, 19:04
Cheer up, it could be worse:
Esprit manifold.
Postby Russc » Sat 06.10.2007, 22:28
Ouch !!! yeah in a way it`s saved me some hassle taking it all off now. Would be sods law that i put it all together and then it went.
Russc
Postby F1 LOTUS » Sun 07.10.2007, 04:22
I think Doc Fizzix rewelded his a while back???
Mine's cracked also - toying with the idea of designing a new one to suit the range of Garrett Turbo's...
F1 LOTUS
Postby abmunro » Sun 07.10.2007, 17:25
F1 LOTUS wrote:toying with the idea of designing a new one to suit the range of Garrett Turbo's...
Go for it!!
I'd be very interested.
I bought a nice Stainless steel one for my GTiR.
Very nice.
abmunro
Postby dapinky » Thu 11.10.2007, 10:54
Well, call me a cheapskate if you want. but when i did my head gasket, i found similar cracks - and asked these same questions, but it appears that there is no deffinative answer to the problem, other than £300 for a new one.
I looked into welding, but couldn't find anyone local to give it a go, and wanted to get it all back on the car......
....so i sand (grit) blasted it to a nice shiney grey colour, smeared a bit of 'chemical metal' on the cracks and put it together.
one year on, and my temporary repair is still solid!
PS - if anyone knows a good Cast Iron welder. please let me know as i now have a spare manifold (also with slight cracks!).
Postby Russc » Thu 11.10.2007, 15:22
Nah not tight at all. I must be honest and say i thought of the same. However as Lotus had them in stock i thought i`d take the advantage and put a new one on while i still can.
I`m going to keep the old one "just in case"
Russc
Postby Elanlover » Thu 11.10.2007, 15:42
Perhaps someone who has removed their manifold can answer a somewhat related quesiotn for me. The shiny plates on the sides of the manifold - are they heat shields? Can they be removed? I ask because I'm considering having a manifold ceramic coated and I suspect they'd want those removed before doing the work. Thanks!
Postby Russc » Thu 11.10.2007, 17:26
I can answer that for you.
Yes and yes :) the bolts do have a tendancy to sieze though so keep some spare time for the possability of having to drill them out.
Russc
Postby GeoffSmith » Mon 15.10.2007, 19:19
dapinky wrote:PS - if anyone knows a good Cast Iron welder. please let me know as i now have a spare manifold (also with slight cracks!).
What about trying some of this Dave?
Postby dapinky » Mon 15.10.2007, 19:35
I remember stumbling accross that one when i first encountered the problem - then i read all about it (well, their advert, anyway!) and decided that my skills and tools were insufficient to make the whole process cost effective.
I would need a different set of nozzles for the gas rig, and with the filler rods, decided it would be easier to find a 'local' tradesman to do the job for me :?
Then i did the temporary repair and forgot all about it till i got my spare manifold and found similar cracks!
Cast welding seems a bit of a black art to me - with stupid temperatures involved to avoid cracking, but not too hot to invoke distortion.
Does anyone know if ceramic coating can be done over chemical metal??
Return to Exhaust
