by SJ » Sat 06.10.2007, 15:07
Due to me being a moron I left the drivers door open the other day whilst the car was on the ramp in the garage. Ramp goes up window goes POP ! What a tit.
So.........I need to know:
Where can I get a window? How much is fitting?
The reason the car was on the ramp was there is a horrible rattling noise coming from the Cam Angle Sensor - would it be best to fit a new one or can this type of problem be addressed?
Thank you in advance for your assistance
SJ
Who wants a ride on my donkey?
SJ
by Dico » Sat 06.10.2007, 19:11
On the ramp for cas inspection ??
I think DaveT 'may' have a window, but he's in the Isle of man for the weekend.
Drop him a PM
Sounds like the bearing in the cas has gone. They are available in the states at a reasonable price. ($100 ? + postage + duty)
Have a look at jimbobs thread in the 'Project' section. I'm sure he posted the part numbers there.
And if you are doing a group buy get me one
Good luck.
- Fool Boy Four - Founder
by SJ » Sat 06.10.2007, 19:15
On ramp for general inspection - new brake lines just fitted and was doing oil change.
SJ
SJ
by Dico » Sat 06.10.2007, 19:32
Was the information I gave to you of any use?
SJ wrote:On ramp for general inspection - new brake lines just fitted and was doing oil change.
Ah, must be me being in a picky mood
by SJ » Sat 06.10.2007, 19:36
Any info is of use Dico - I don't know s**t, you lot are my lifeline!
Frightened of cost on window though
SJ
SJ
by Dico » Sat 06.10.2007, 19:37
£50 may do it
(plus fitment
Unless he's sold em?
Stevieshag may have one also?
I have a garage full of spare for such eventualities
by SJ » Sat 06.10.2007, 19:45
I have full SE Torbo as spare at mo but that was the window I broke! Glad it wasn't mine, you'll see it for sale soon I'd imagine - just new hood and an MOT and sort stuck wastegate.
I'll put it on here first rather than e-bay - I rekon about £3k. BRG H plate 99 thousand miles with shoddy re-spray (not that bad)
Fancy it?
SJ
SJ
by Dico » Sat 06.10.2007, 19:49
Hmm, 'Mrs Dico do you mind if I have another £3000's worth of spares in the garage?'
Can't see it happening, but its sounds cheap enough
by SJ » Sat 06.10.2007, 20:01
If you know anyone that needs it get them to send me a message - like I say, minter she isn't but a bit of TLC and you have a £5k car.
Open to offers before I do the bits I intend to.
SJ
SJ
by Sy V » Sun 07.10.2007, 06:17
SJ
Later today, I'm delivering a car to Surpherphil in High Wycombe.
In the boot are two side windows - already removed.
You might want to approach him.
FYI windows come in two tints - Greeen and brown (bronze). These are green - but you can hardly tell them apart.
Note: I have just locked your identical thread in the Problems area. Duplicate threads cause nothing but problems. I've copied my reply into this one, above.
- LEC Godfather
by Specky » Sun 07.10.2007, 11:14
Sy V wrote:FYI windows come in two tints - Greeen and brown (bronze). These are green - but you can hardly tell them apart.
Unless you have a mix and match fitted to your car..
by GeoffSmith » Fri 12.10.2007, 16:23
The hall effect sensor HES is the electrical sensor inside the CAS. It sounds like SJ has a problem with the bearings in his CAS so, unfortunately, replacing the HES will not solve his problem.
- Kitty Fiddler
Return to Doors and Windows
Users browsing this forum: Google [Bot] and 2 guests
