ESM Chips - Performance & discussion
Postby Doug » Tue 18.09.2007, 00:56
Excellent work, Alan!
Maybe when the guys hit the factory for the anniversary event they can hint, "how about we strap a 4XE1-T to your dyno for some chip work."
It won't happen if you don't ask--how cool would it be if they agreed! Might even be worth flying over to see!
Postby Elanlover » Fri 21.09.2007, 21:23
Alan, does this mean you've found a way to squeeze even more power out of the engine - over and above the current V5 chip???? :shock:
Postby ESM » Fri 21.09.2007, 21:31
Elanlover wrote:Alan, does this mean you've found a way to squeeze even more power out of the engine - over and above the current V5 chip???? :shock:
Perhaps - its unproven as yet
ESM
Postby Elanlover » Fri 21.09.2007, 21:53
Then I await provement with interest :-D
Postby palchiu » Sat 22.09.2007, 06:13
Put the Everest chip in my Elan last night, wait the rain stop and test drive.
Lucky, everything going right when engine idling.
Thanks ESM!
Elan S2 #772 (Silk Red)
palchiu
Postby ESM » Fri 28.09.2007, 20:24
Glad you got it. Its the first one I've sent to Taiwan 8)
ESM
Postby surfboardfiller » Fri 05.10.2007, 12:34
Just to let you know that my chip is working nicely and I'll do some runs soon with Elanscan!
Thanks! :-D
surfboardfiller
Postby ESM » Sat 06.10.2007, 13:38
8)
ESM
Postby Gazza » Tue 09.10.2007, 14:32
Alan
You have PM
Cheers, Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby paulwatkins » Sun 21.10.2007, 16:01
I had a rolling road session yesterday organised by a local car club.
Unfortunately I missed a trick and forgot to take my laptop to take a scan whilst it was being done! :oops:
Anyway, here are the figures (taken in 4th gear)
Engine output: 187.5 bhp
Wheel output: 146.5 bhp
Max power at 103 mph or 6310 rpm
Torque: 153 lbf-ft
Max torque at 96 mph or 5860 rpm
Max speed: 108 mph
Max rpm: 6620 rpm
paulwatkins
Postby Dico » Sun 21.10.2007, 16:22
Which chip have you got Paul?
Exhaust? Dump valve?
Keep meaning to take mine. Once I get round to fitting the chip!
Postby paulwatkins » Sun 21.10.2007, 19:49
Paul,
I've got:
an Everest chip (v4 I think, maybe Alan could confirm)
a K&N air filter (in the trashcan)
a forge recirculating dump valve
a Peco exhaust
and oversize pistons :lol:
I'm really annoyed with myself for not taking an Elanscan of the run. :roll:
paulwatkins
Postby John_W » Sun 21.10.2007, 21:09
Paul,
For that setup, 187.5 BHP seems low to me. The various data from my car and that which I've received from others suggests you should be seeing over 200. When was the last time you checked your base timing, as that might be a good place to look for missing horses?
The ElanScan run would have been good to see.
Postby GeoffSmith » Sun 21.10.2007, 21:36
I agree! Base timing can make all the difference and you should have done an ElanScan run! :chair:
Postby paulwatkins » Mon 22.10.2007, 07:42
The base timing is fine. I regularly check that - every 2 to 3 weeks or so! It was done last wednesday evening! (Believe it or not, it nearly always needs slight adjustment! - So check yours too! :-D )
Reading on the forum, there is a general consensus that most of the readings taken were very conservative to say the least - the 4wd cars coming out even worse than the 2wd.
Some cars came out as expected, but most were well under what would be expected considering the mods that they were carrying!
There is also a feeling that the operators were not very competent.
So, these results can probably be ignored as lacking accuracy!
paulwatkins
Postby GeoffSmith » Mon 22.10.2007, 13:11
When I looked into it, there are many sources of error and a lot of ways of making the "before" and "after fitting an expensive piece of junk" comparison look very good!
Postby G UK » Thu 29.11.2007, 21:40
Just ordered my V5 and Switcher. Cant wait for it to arrive :smt026
G UK
Postby Hasbro » Fri 30.11.2007, 01:38
John_W wrote:Paul,
Perhaps it would help if the type of Dyno were mentioned by everyone. It's apples and oranges when trying to compare.
Dyno-Jets are the most common here in the US although they can vary a bit due to operator, elevation and other factors but they at least make it easier to compare. I'm not saying Dyno-Jets are the best, just the most common.
Hasbro
Postby surfboardfiller » Fri 30.11.2007, 10:27
paulwatkins wrote:Paul,
I've got:
a Peco exhaust
Oversized pistons soaking up all that energy? I wonder if it's like a banger going off in a cave in you cylinder block, less power with bigger pistons if you don't add more fuel to fill the space? :shock: :wink:
surfboardfiller
Postby G UK » Thu 06.12.2007, 19:28
Recieved, Fitted & Tested. One happy customer here!!!
G UK
Return to Upgrades
