Which Gearbox oil.... again!!
Drivetrain problems
Postby dans » Mon 01.10.2007, 17:46
hi all,
Sorry, I know this one has been round a few times..... but....
I'm looking to get some Redline Gearbox oil to see if it will improve my shifting, as others have found.
What I can't figure out is which one to get for. I asked redline and got told:
just check what grade and viscosity is recommended for your
particular car- if it needs an 80 weight you need Red Line MTL- if it needs a 90 weight you need MT90 which is the heavier grade of the same product.
From reading around I think most people are using the MTL product but a there seem to be alot of references to 90 weight.
Reading through the descriptions on Redlines productpage I'd lean towards the 90 weight as being the correct one
Anyone advise on their opinion of which is likely to make more difference to a dodgy shift?
Thanks,
Dan
dans
Postby M100 TWO » Thu 25.10.2007, 09:53
Just put in Silkolene Pro SRG75 (75W90 GL4) it has helped with the problematic third gear change, so an improvement over the Castrol TAF-X, Quaife recommend this grade of Silkolene for there diffs.I also stroked the sump plug with a strong magnate to magnetize it, to collect any metal particles that are suspended in the oil up to the next service
john
M100 TWO
Postby ivar » Tue 08.01.2008, 12:07
I have used Redline Heavy Shockproof for a couple of years, and it works very well.
_____________
Ivar
ivar
Postby Oliver » Sun 11.05.2008, 10:48
Castrol seem to have discontinued TAF-X, which is a bit annoying as i have still got a litre. I can`t get Silkolene easily where i am, any other suggestions as to a suitable trans. oil ? Is SMX - S 75W-85 / API GL1-4 suitable ? Halfords stock this.
Oliver
M100 N/A - No PAS
RenautSport Megane 275 Cup
MGF
Benelli 2C
Oliver
Postby muley » Sun 11.05.2008, 12:00
Another vote for Silkolene Pro SRG75 (75W90 GL4) from me. You can order it online or phone from opieoils (see website)
Works well (so far!)
Postby muley » Sun 11.05.2008, 12:03
Oliver,
I recently bought ENEOS Premium Multi Gear 75W/90 from japarts (off the web)
It's a GL-5 spec and it seems fine in the Honda snotter.
I'm sure it would be fine in the Elan ..
HTH
Postby router » Mon 12.05.2008, 08:02
Oliver, try SJsportscars they still sell Castrol TAF-X.
Neil
router
Postby Oliver » Wed 14.05.2008, 22:53
Hi everyone,
Thanks for the advice, as usual impatience got the better of me and i have refilled the box with Castrol SMX-S from Halfords. Hopefully it`s ok stuff.
Best Regards
Oliver
M100 N/A - No PAS
MGF
Benelli 2C
Oliver
Re: Which Gearbox oil.... again!!
Postby esprit888 » Tue 02.12.2008, 22:39
Has anyone tried or have anything to say about the royal purple synthetic 75/90W oil for the trans. ?
esprit888
Postby esprit888 » Tue 02.12.2008, 22:53
Here is the royal purple cross reference list, any recc. ?
www.royalpurple.co.za/techa/tranxref.html
esprit888
Postby Exbury » Fri 01.05.2009, 15:35
I am interested in getting some Redline MT-90 both for the Lotus and the MR2. Does anyone else need any as I can get it down to £11.50 a bottle. Can hand deliver in Welwyn Garden City, hatfield, Southgate, Bedford area.
All I need is another 3 or 4 owners needing fluid! Not looking at making a profit but helps save a few £'s
Exbury
Postby philip_sloper » Sat 15.08.2009, 21:53
Paul Matty use Miller 75/90CRX fully synthetic.
It seems to work well in my car.
philip_sloper
Postby Coupeboy » Fri 18.09.2009, 12:36
I have seem to have acquired the third gear crunch when changing quickly up from 2nd at 4000 rpm+. A slightly slower change will not cause the crunch. I would like to 'change' my gearbox oil to the Silkolene as two posters have stated an improvement/elimination of this crunch. However, searching for the recommended Silkolene Pro SRG75 (75W90 GL4) I find only Silkolene Pro SRG75 75W (not suitable for hypoid gears - us?) or Silkolene 75W90 on the http://www.opieoils.co.uk website. Could Muley or M100 Two identify which, exactly, they bought (what does it say on the label?). Thanks
1992 Elan Pacific Blue SE
2007 325se Coupe
Coupeboy
Postby tigerdog » Fri 18.09.2009, 14:19
And of course, none of the above recommendations exist on this side of the Atlantic, save Redline. In addition to recommending brands, then, is the general consensus that it's best to use a 75W-90 fully synthetic gear oil?
Postby rip » Fri 18.09.2009, 14:47
tigerdog wrote:And of course, none of the above recommendations exist on this side of the Atlantic, save Redline. In addition to recommending brands, then, is the general consensus that it's best to use a 75W-90 fully synthetic gear oil?
Made a huge improvement with mine.
