Chrome trim Rings for your 3 Gauges
Postby Guest » Tue 21.03.2006, 20:13
Hi guys,
Which chrome ones did you order off the web site? Can't find them off the first link?
Also there was no reply to ab2cv question do the heater rings work?
Guest
Postby PaulN » Wed 22.03.2006, 10:16
Anonymous wrote:Hi guys,
Hi,
I Found a great place who are pretty close to me:
http://www.lmfvauxhall.com/prodCatalog/ ... eptIndex=0
You need to sets though!
Im after a spare one as had a Blonde Moment with one of mine! So Pm me if you get some.
PaulN
Everything Happens For A Reason!
PaulN
Postby Guest » Wed 22.03.2006, 13:03
Will do it'll be april before i i get them i'll message you then
dave
Guest
Postby paza1 » Fri 24.03.2006, 23:11
Is this a possible group buy scenario?
Silver 1992 SE Turbo.
paza1
Postby PaulN » Mon 27.03.2006, 08:46
paza1 wrote:Is this a possible group buy scenario?
Possibly yes.............. but it would take about 10+
Im not sure what if any kind of saving you would get either...
PaulN
PaulN
Postby chris.t » Mon 27.03.2006, 13:45
if there is a group buy put me down for a couple of sets.
if a group buy is possible could they provide exactly what we want without having to buy 2 sets
cheers chris
Postby Rogerf » Mon 27.03.2006, 13:58
Yes,i'd also be interested!
Roger.
Rogerf
Postby paza1 » Mon 27.03.2006, 19:39
There would be a small saving because for every 2 sets bought there will be one ring spare. 10+ quantity may also yield a discount.
Mark
paza1
Postby erod » Fri 19.05.2006, 13:35
Im in.
erod
Postby tweetdriver63 » Sun 14.10.2007, 06:05
I was just playing on the UK ebay site, and saw several of these listed. These look like they would fit our Elan instruments. Could tie in nicely for those who've put on the chrome rings around the round gauges.
clicky here
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby erod » Thu 18.10.2007, 14:17
I'm in for the three rings for the gages as well as the set for the instrument pannel.
erod
Postby Elanlover » Thu 18.10.2007, 19:33
That's a good find tweet. I bought the rings for the 3 gauges and it does improve and update the look. Those rings had to be "modified" to fit propoerly but it all worked out in the end. I think I'll place an order for a set.................
Postby tweetdriver63 » Thu 25.10.2007, 20:28
I found another option for those still interested. I think these are a bit less costly, too.
I bought two sets of these on ebay. I had to get two sets because he was selling them in pairs for the Mercedes. I bought one set to check the fit before buying more. I put the two on that came today, and they are a perfect fit for the 3 guages, although they don't fit in the heater/ac knobs. I think they would if you cut them, just like those Vauxhall ones above.
Based on the pictures above, I'd say these are a little narrower, but they do look really good. I'll post a pic when I get home this afternoon. They have the adhesive already on them, so all you do is take them out of the little bag and stick 'em in place. I takes all of about 2 seconds.
I sent the seller a message, and he already replied that he can get more, and he will sell them individually, or in sets of three. He's getting me a ball-park price on 3-piece sets, based on ten sets sold. I'll get back as soon as he gets me that, which probably won't take long. He answered my first message in about 5 minutes.
'91 Elan SE
tweetdriver63
Postby Elanlover » Thu 25.10.2007, 20:48
The rings for the guages won't fit the Temp and Fan controls (as you already know). I contacted a seller recently regarding rings for the mercedes that I had hoped would fit. he told me he can provide them in 57mm or 58.5mm diameters. Haven't yet measured to see if any of those sizes will fit. Don't know when I'll get to it but when I do, I'll let you know if either will fit.
Postby tweetdriver63 » Thu 25.10.2007, 20:55
Elanlover wrote:The rings for the guages won't fit the Temp and Fan controls (as you already know). I contacted a seller recently regarding rings for the mercedes that I had hoped would fit. he told me he can provide them in 57mm or 58.5mm diameters. Haven't yet measured to see if any of those sizes will fit. Don't know when I'll get to it but when I do, I'll let you know if either will fit.
Before I bought those on ebay, I asked the seller for the diameter and he said 56mm. I don't know if he was talkng outside or inside diameter, but I'll assume inside. Anyway, the Mercedes rings do fit the three gauges perfectly, but my first inclination is to say the 58.5mm ones will be a little bit too big. (I'd go for the smaller ones, or if you want to wait, I think I've got us a group buy on the ones I got.) When I was cutting the faux-carbon-fibre trim for that area, I measured the openings, and cut 57mm holes for the guages, which worked nicely, so I figured his 56mm response meant they would likely work. Basically, I'd say they are 2 1/4'' gauges.
'91 Elan SE
tweetdriver63
Postby tweetdriver63 » Thu 25.10.2007, 21:01
Sorry if I sound like one of you Brits, but Bugger! This guy's fast. I just asked him about sets of three, and he's already got them listed on ebay.
Click here.
He's showing three sets available, but if you miss out, I'll bet dollars to doughnuts he'll get more.
'91 Elan SE
tweetdriver63
Postby tweetdriver63 » Thu 25.10.2007, 23:51
OK, here's the pic I promised. I took it with only two rings installed so you can see what a difference they make.
'91 Elan SE
tweetdriver63
Postby Enright » Sun 28.10.2007, 22:33
Don't overdo it with the bling Tweet, or you'll end up with another Benkmobile! Or even worse, Game-On.
Postby tweetdriver63 » Sun 28.10.2007, 22:41
Enright wrote:Don't overdo it with the bling Tweet, or you'll end up with another Benkmobile! Or even worse, Game-On.
The carbon-fibre stuff is actually very subtle, not like red, or even polished aluminum, and so are the chrome rings. I think you can tell both from the above picture. Also, the carbon-fibre was pretty much a necessity because of the multiple shades of grey and black on the console, specially after I installed the volvo cupholder.
This is not the kind of car for flashy blingy stuff, or obnoxious colors. I'll leave that to the 16-25 year old crowd and their hondas. :gray:
'91 Elan SE
tweetdriver63
Postby Elanlover » Sun 28.10.2007, 22:46
I'm right there with you on the chrome trim rings. Its very subtle and just the right touch of "modern" to bring the interior at least one decade closer to today.
Return to Interior
Users browsing this forum: Apple [Bot] and 1 guest
