NormScan
NormScan
Postby GeoffSmith » Wed 05.09.2007, 12:51
ESM posted a trial program back in July for all you Norma owners, but it has only been downloaded a couple of time.
Just wondering whether anyone had tried it out and has some logs to share?
Geoff
Postby Sy V » Wed 05.09.2007, 13:46
Oh, I missed this!
Does it read out tread-wheel RPM and hamster heartbeat rate?
LEC Godfather
Postby GeoffSmith » Wed 05.09.2007, 18:19
Don't knock it. It's with an advanced optically isolated communication system useful up to 800m.
semaphore. :lol:
Postby Oliver » Tue 30.10.2007, 18:52
Sy V wrote:Oh, I missed this!
They ain`t that slow Sy, i regularly follow an SE round some East Sussex `B` roads and although he pulls away from me out of slow corners, he seems to hold me up the rest of the time. Weird but true. I won`t divulge his identity! Maybe i`m just a better driver ? Or maybe with an N/A you can just keep it floored (i do!).
Oliver
M100 N/A - No PAS
RenautSport Megane 275 Cup
MGF
Benelli 2C
Oliver
Postby Rambo » Tue 30.10.2007, 19:18
They ain't that slow Sy, i regularly follow an SE round some East Sussex `B` roads and although he pulls away from me out of slow corners, he seems to hold me up the rest of the time. Weird but true. I won't divulge his identity! Maybe i'm just a better driver ? Or maybe with an N/A you can just keep it floored (i do!).Oliver
It's not a West Sussex interloper in a NMY perchance ? :burnout:
Postby Specky » Tue 30.10.2007, 20:36
Oliver
But when I use second gear....
Postby Oliver » Sat 10.11.2007, 18:05
Sorry, bak to the matter in hand, i have tried NormScan, unfortunately it produced the same results as ElanScan, bad echo.
Oliver
M100 N/A - No PAS
MGF
Benelli 2C
Oliver
Postby Gary » Sat 10.11.2007, 19:23
I think that means you haven't set the correct port on the laptop
Postby Oliver » Sun 11.11.2007, 11:29
Hi Gary,
No, i am sure the COM port wasn`t an issue. When i first tried ElanScan i borrowed some kit from Geoff that confirmed the interface was talking to the software.
Oliver
M100 N/A - No PAS
MGF
Benelli 2C
Oliver
Postby GeoffSmith » Sun 11.11.2007, 11:43
The problem is trying to find the right command to get the N/A ECU to respond - this was what Alan's program was attempting to do. The fact that there was a stack of bad echos implies that it did not. :cry:
Postby ailwyn » Mon 12.11.2007, 10:51
geoffsmith wrote:The problem is trying to find the right command to get the N/A ECU to respond - this was what Alan's program was attempting to do. The fact that there was a stack of bad echos implies that it did not. :cry:
Um... I was under the impression that because it's a 1 wire setup everything that was sent by the PC was also received by the PC?? Hence the echo.
If this is the case, then it sounds like the requests are not reaching the ECU.
ailwyn
Postby Oliver » Thu 15.11.2007, 18:45
I have asked Lotus if they would consider adding the N/A ECU to the aftersales parts list. I`ll let you know what happens
Oliver
M100 N/A - No PAS
MGF
Benelli 2C
Oliver
Postby clemo » Thu 15.11.2007, 20:28
hey ... what ....
missed this thread for only what .... months..
will have to get my cable back from that long hair'd yobo in the big smoke..
and then give it a go...
oliver fancy a good laugh..
lets go up to the turbo thread and rip the P1$$ out of all the sticking wastegates , porting failures and overboosting problems...
oh my sides..
now whos go the fastest car..
clemofspeed..
ps i noticed when these guys are changing gear how slow the pick up is , whilst out better fianl drive and higher rev range keeps up and dare i say it ......
maybe i should get my NA and s2 together and see...
anyway back to topic ..
would / will love to give it a test ...
thanks alan foir coming up with this little beauty..
clemo
clemo
Postby Oliver » Fri 16.11.2007, 18:21
Oliver wrote:I have asked Lotus if they would consider adding the N/A ECU to the aftersales parts list. I'll let you know what happens
Oliver
Unfortunately, they havan`t got any.
Dave Massey of Lotus recommended : http://www.injectioncorrection.co.uk/
M100 N/A - No PAS
MGF
Benelli 2C
Oliver
Postby Oliver » Fri 16.11.2007, 18:28
Hi Clemo,
Yes the old NA is a bit simpler and lighter, but i must be getting old because i actually wanted a SE / S2 final drive to make the car more relaxing on my european jaunts. I suppose i could fit some S2 16 inch wheels to raise the gearing.
Anyway back to topic :!:
I may try http://www.injectioncorrection.co.uk/ , to see if i can get my faulty original ECU repaired. I`ll ask for a quote and let you know how much they want.
See you soon hopefully,
Oliver
M100 N/A - No PAS
MGF
Benelli 2C
Oliver
Postby Oliver » Fri 23.11.2007, 23:11
Clemo,
Have you tried NormScan yet ??
Oliver
M100 N/A - No PAS
MGF
Benelli 2C
Oliver
Postby clemo » Fri 23.11.2007, 23:25
waiting for that long haired taxi bloke to find his way to a post box in sarf luden and post on back my lead...
apart from that the car is in bed for the winter..
but will give it a go whe TIMMO posts it back..
all well with yours?
clemo
Postby timmo » Sat 15.12.2007, 00:29
Post box, cant even find me way to the pub currently, soz Dave!
timmo
Re: NormScan
Postby GeoffSmith » Thu 08.01.2009, 23:58
Just run NormScan on my ECU emulator and have these words of wisdom:
From the <Setup> menu, hit <Autodetect ALDL frame id>.
A pop up box will prompt you to connect the pc to the ALDL and to turn the ignition on.
Press <OK>
If the Error log box says "Bad echo (sent: F4 56 01 B5 received: XX XX XX XX)" then there is a problem with the interface - usually the lead is not connected properly or the ignition is not turned on (remember immobilisers).
Otherwise, the program takes about one minute to run - the Error log box should fill up with "No reply" messages and may appear to freeze, but don't worry, after a minute you will get a popup box appearing.
If the message is "No valid reply detected" then we are back to square one. :banghead:
However, if the message is "Success: Frameid is XX and the data size is YY" then report back what XX and YY are and we are one step further forward. :banana: Press [F1] to start talking then [F2] to log some data. Try moving the accelerator and see if any numbers change. Press [F4] to stop logging and [F3] to stop talking. Select <File> <Save> and give the log file a name - zip up this .ecu file and post it up here.
Re: NormScan
Postby Oliver » Fri 09.01.2009, 21:27
Geoff, I`ll try it this weekend and let you know the result ASAP. I know my ElanScan interface works - it does the business on my brother in laws SE.
Oliver
M100 N/A - No PAS
MGF
Benelli 2C
Oliver
Return to ElanScan
