Enright wrote:Being as their wiper stalks (with a variable intermittent wipe control) fit perfectly, and have S and R buttons incorporated into them, I reckon the rest of the system may be easily sourced from a scrappy, and transplanted.
Doug wrote:any suggestions?
you could switch your boost gauge to one that takes a direct tube to it and dispose of the separate transducer--then use that space for the jar of mayo
GeoffSmith wrote:Chris, you still need a mechanical input to open and close the throttle body butterfly - the TPS merely gives an indication of the butterfly's position so that the ECU can inject the correct amount of fuel.
(one ground and one pulsed 12V?) Or even better, does it have a specific colour so i can find it easy? I'd hate to solder a cable twice
