by scorpmontecarlo » Sat 19.01.2008, 20:33
I have had the car parked for a while with the top folded up and now I
put the top up and it is not going down all the way in the rear section
below rear window . Is there an adjustment????
love all serve all
no guns drugs or
nuclear weapons
allowed inside
scorpmontecarlo
by lotuska » Sun 20.01.2008, 14:58
Check the following
thread, I think there are some more on the same subject.
lotuska
by max and andy » Fri 27.02.2009, 11:24
Does anyone have the problem of the back edge -seal marking the lid of the stowage conpartment. When soft top up .Any way of solving this problem.I was thinking to put vaseline along the seal edge to make the rubber more supple and less abrasive .Has anyone tried this ? Or does it just make a mess. Max&Andy
s
max and andy
by theelanman » Fri 27.02.2009, 11:31
yep most people...!!!!
the most sucessful solution IIRC was armourfend.....or something similar
by max and andy » Fri 27.02.2009, 12:16
Whats IIRC ?Whats Armourfend? Max&Andy
max and andy
by theelanman » Fri 27.02.2009, 12:21
IIRC = if i remember correctly
and armourfend is a transparent plastic sheet that you put ontop of you paint to stop it chipping....or in this case yer rear deck
by max and andy » Fri 27.02.2009, 12:51
So you dont rate the lubing the rubber idea ?Does the lid look much differnt when covered? With the plastic i mean not the vaseline smeared all over the place. Max&Andy
max and andy
by Jackonicko » Fri 27.02.2009, 12:53
No, no, no, no, no, and no!
Jackonicko
by theelanman » Fri 27.02.2009, 13:21
why lube?.....you'll just leave a greasey mess on the deck when you put the hood down
the armourfend is totally transparent....so no...you wont see it
by max and andy » Fri 27.02.2009, 13:30
If most Elan owners have the same abrasions .Do most use the plastic coat? max & andy
max and andy
by theelanman » Fri 27.02.2009, 13:41
people generally put the armourfend stuff on after theyve had a respray or had the deck painted.....
if its marked then it marked and has taken 15 years to get to its current state.....its up to you
if your deck is marked already...what are you worried about?.....
by GeoffSmith » Fri 27.02.2009, 14:23
Jackonicko wrote:No, no, no, no, no, and no!
:I agree: I don't think that petroleum products should be used with the seals.
- Kitty Fiddler
by Gordon » Fri 27.02.2009, 16:20
AFAIK vaseline rots rubber dosent it - not the best thing for (what I would imagine is) an expensive rubber seal...?
I've put an armourfend style product on mine - I've still got the paper templates that I used to cut it - nearly threw them out the other day. I seem to remember the sheet of film was about £10, and floating it on wasnt rocket science...
I'll take some pictures when I get a minute, you'd hardly know it's there, and it solves the problem once and for all...
Gordon
1990 M100, Calypso Red
2005 Vectra C....
Gordon
by Gordon » Sun 29.03.2009, 16:03
Gordon wrote:I'll take some pictures when I get a minute, you'd hardly know it's there, and it solves the problem once and for all...
Gordon
Finally got a minute!!!...
Protected rear deck...
2005 Vectra C....
Gordon
by Enright » Sun 29.03.2009, 16:06
Looks good. Where did you get it from?
Neil
- Modificator
by max and andy » Sun 29.03.2009, 16:39
With your templates If i reimbursed the cost of the Armourfend could you pre-cut me a lump for Maxines. Or i could send you a piece. Plus a little drink offcourse. Andy
max and andy
by Gordon » Sun 29.03.2009, 18:10
I'm pretty sure I got it off this guy:
film on eBayPrice looks about right from memory...
Obviously you can see it up close, but it dosent catch they eye (like a scratched deck does...)
M&A - I think I've got my templates somewhere are you coming to donny?
2005 Vectra C....
Gordon
by RichardK » Sun 29.03.2009, 18:34
Definately NOT vaseline or other petroleum based product on your seals......condoms...rot...unwanted pregnancy etc etc.....
I use a silicon grease on my rubbers - food grade if you can get it (used on scuba orings)
RichardK
by ektrolleyboy » Mon 30.03.2009, 14:10
max and andy wrote:Does anyone have the problem of the back edge -seal marking the lid of the stowage conpartment. When soft top up .Any way of solving this problem.I was thinking to put vaseline along the seal edge to make the rubber more supple and less abrasive .Has anyone tried this ? Or does it just make a mess. Max&Andy
s
Every cab' I've ever had did this, except the ones where the hood folds without the rear lifting. Only solution is a guard of some description as previously mentioned. Vaseline is supurb for cabriolets with windows that fit inside seals (a proper design that doesn't leak, unlike the crap seals we have!) to stop squeaks that develop over time as the roof flexes over the windows. Great on the Ferrari F355 GTS and SLK's/SL's too... And other hard-top cabriolets.
ektrolleyboy
by Don.Hasi » Tue 31.03.2009, 20:37
@Gordon: as you have said it before... one can see nothing on your picture. Very good solution
So what have you protect in detail? The complete lid or only the special section/a stripe?
Don.Hasi
