by MattDon » Sat 26.01.2008, 01:20
on the way home the tonight the car was not firing rights and seemed to loose all power for a moment when i put my foot anything past about 10% does this sound familiar to anyone, all help greatfully received.
changed the title, i seem to have a million questions or problems though id use this thread instead of filling up the forum.
MattDon on Wed 30.01.2008, 21:53, edited 1 time in total.
MattDon
by Doug » Sat 26.01.2008, 07:51
- Code: Select all
CCCCCCC
C
C
C
C
C
CCCCCCC
A
A A
A A
AAAAAAA
A A
A A
SSSSSS
S
S
S
SSSSSS
S
S
S
SSSSSS
- LEC Founder
by M100 TWO » Sat 26.01.2008, 10:15
coil, but change the plugs first it is the cheapest option, working to the most expensive in your elimination.
M100 TWO
by MattDon » Sat 26.01.2008, 19:35
took it out for a spin today with no problems at all, i think i might have a gremlin, its not the first time ive had a problem that just went away. im gonna get plugs,ht leads, coils and a hall effect sonsor though, just incase it comes back.
there was no warning light and if i accelerated slowly it would rev right up.
MattDon
by PAUL30 » Sat 26.01.2008, 20:01
I had a similar problem, would only misfire under load.One of the coils had a bit of rust on it.Just repalced both. One of the sparkplugs was also affected, covered in green powder.Probably dampness.
PAUL30
by GeoffSmith » Sat 26.01.2008, 22:08
There have been a few problems which could be related to damp on the HT side which wouldn't flag up an error code. It's been pretty wet and damp recently, so it may just be a case of drying it out.
- Kitty Fiddler
by Doug » Sun 27.01.2008, 19:44
or it could be the . . .
when was it last changed?
- LEC Founder
by MattDon » Sun 27.01.2008, 21:55
i drive almost every day, so i cant see how it could be damp, especialy when its been some much dryer the last few days. Doug, it could be what?
went for a drive today, and had noisey tappets for the first 5-10 mins
i wouldnt mind so much but the engine was replaced a few years ago, i think its got less than 70k on the clock
think i should start a thread called todays problems
MattDon
by dermotbell » Sun 27.01.2008, 22:19
MattDon wrote:went for a drive today, and had noisey tappets for the first 5-10 mins
Had you not driven it for a few days?
This is known to happen if it sits for a while, the should quieten down if you war the oil to operating temp.
Dermot Bell
dermotbell
by MattDon » Mon 28.01.2008, 02:25
it might have been left for a day or slightly more. this is the first time its done it since i got it in november, and i drive it most days. i can hear the tappets normaly, but its not bad and i assumed it wasnt anything to worry about, but today you could hear it clearly while driving.
MattDon
by Specky » Mon 28.01.2008, 11:41
What grade of oil are you running?
See
HERE if it gives you idea... Trend analysis and all that..
by MattDon » Tue 29.01.2008, 11:27
not sure mate, ive only had it a few months, looking to change all the fluids in the next couple of months, useful link there.
ok sticking with the todays problem theme, i think my drain hole thingy might be blocked, ive had a small pond in my footwell for over two weeks now. where is said drain and how do i access it?
MattDon
by Candles » Tue 29.01.2008, 11:55
Ponds in the footwell are normally water spilling over the sills when parked in the rain facing downhill!
Candles
by MattDon » Tue 29.01.2008, 15:04
its been garaged for the last couple weeks and covered while its at work, been droping a news paper in there every evening and morning to try to soak up the water without much joy.
MattDon
by Specky » Tue 29.01.2008, 15:33
Have you been driving it in the wet?
Bulk head seal/gromet gone...?
by MattDon » Tue 29.01.2008, 17:06
yep i drive it everyday. will have a look at that.
MattDon
by Doug » Tue 29.01.2008, 22:24
what I'm getting onto is the notorious problem of the Hall Effect Sensor, within the CAS (cam angle sensor). It goes bad over time and causes problems and a lot fo time will throw a CEL (check engine light).
I rec you read up on this problem and how to check for a stored CEL on your car and check for it.
you say the computer limited the engine revs and this is the prime suspect
- LEC Founder
by MattDon » Wed 30.01.2008, 18:40
thanks for all the advice so far, and all suggestions are being looked into.
todays problem (not a big one.... i hope) but my mechanic said i need to replace the rear roll bar and linkage.
on the plus side i should have my new peco installed this time tomorrow.
HOLY CRAP theyre £175, for a metal bar!?
MattDon
by MattDon » Sat 02.02.2008, 17:22
so rather predictabley im getting boost creep, i know the gauge isnt the most accurate but its often shooting past 1bar then slamming me forward, happened today while over taking, not ideal. so fingers crossed the pce arrives soon, or should i start porting now and fit the pce when it comes? not looking forward to trying to remove it, might just tempt my local garage to do it for me, atleast to remove it anyway.
also my bailey dump valve is "dumping" when on part throttle, not a major problem but might look into the greddy rs, its also amusing listening to the hiss build up and getting the hit of the turbo.
MattDon
by M100 TWO » Sat 02.02.2008, 18:57
The way to stop the bailey from parsing on part throttle is to fit there twin piston DV26 you will have to send the body back to them and they will fit new internals to either the atmospheric, or the re-circulating body it is also quieter in operation
john
M100 TWO
