Rear lights conversion
Postby chrisP » Tue 19.02.2008, 14:11
Hi I have not seen the new style LED lights in person, but they seem to be a straight replacement. worth checking with Lotus to find out if the plugs are any different on the rear.
Tony thats interesting to note that you did not have to do any filing, all Elans are truely unique :-)
chrisP
Postby nissias » Tue 19.02.2008, 17:23
addict wrote:why not use fiat coupe rear lights they must be cheep
yeah but would they fit in the round frame available?
nissias
Postby abmunro » Tue 19.02.2008, 17:36
Here's a pic with the lights on.
:-D :-D :-D :-D :-D :-D
abmunro
Postby nissias » Tue 19.02.2008, 17:43
can anyone find out if the new led lights are the same size as the old ones?
i am in the us so i do not really know who to call.
the guys down in the uk r the experts
nissias
Postby Monty » Tue 19.02.2008, 22:13
nissias wrote:i am in the us so i do not really know who to call.
errrrrrr Lotus :roll:
Postby nissias » Wed 20.02.2008, 15:41
the Lotus guys in the US suck!
they don't have a clue
nissias
Postby Nige » Wed 20.02.2008, 15:54
The LED lights are the same diameter as the earlier bulb versions and mount in the same way. I'm not sure about the depth but memory tells me they are the same again, as far as I know the LED and earlier rear lights are completely interchangeable. Best person to comment is SurferPhil, as he has made rear panels to take all the S2 Elise lights.
Back in Blighty
Nige
Postby surfboardfiller » Wed 20.02.2008, 16:29
nissias wrote:can anyone find out if the new led lights are the same size as the old ones?
The LED's are slightly deeper than the bulbs and weigh a lot less, but are prone to failing.
surfboardfiller
Postby Nige » Wed 20.02.2008, 16:43
As if by magic, along came Phil :-D !
Back in Blighty
Nige
Postby shinny » Fri 22.02.2008, 13:47
Great looking conversions you have there. When I was looking at buying an elan, this would have been high on my to-do list. (I ended up with a rev5 mkII MR2 instead)
Anyway, I'm looking at using the Elise S2 '06 LED lights for a conversion on my MR2. Would someone be able to measure them for me and tell me what diameter they are? (obv. the bulb units are the same size, so either unit will do)
Many thanks in advance...
shinny
Postby nissias » Sat 23.02.2008, 22:30
so what's the total for the complete conversion???
nissias
Postby abmunro » Sat 23.02.2008, 22:40
For mine
£230 light pods
£160 Elise lamps
£100 Painting
£35 Elise lighting cabling
£525 in total
abmunro
Postby nissias » Mon 25.02.2008, 04:18
abmunro wrote:For mine
£230 light pods
£160 Elise lamps
£100 Painting
£525 in total
not bad
nissias
Postby addict » Mon 25.02.2008, 19:38
i was suggesting the person making the frames used coupe lights instead of lotus :roll:
addict
Re: Rear lights conversion
Postby Ade » Mon 22.06.2009, 21:28
Hi all,
I am fitting one of Chris Phipps panels but did not want to use elise lights. I think I have found an excellent alternative from stafford vehicle components. They are the premier led lights, mix and match. I recieved mine to-day and am over the moon with them. If you oder any make sure you buy the chrome bezel they look absolutely great, a real good fit. When fitted you will have four side lights four brake lights, plus indicators fog light and reverse. I,ll post photos when complete but in the mean time have a look before you buy any other lights. By the way they are much cheaper.
Ade
Ade
Postby Ade » Thu 02.07.2009, 22:50
Photos.
Ade
Postby Elanlover » Fri 03.07.2009, 01:12
Those look quite nice and probably little visibale difference from the Elise lights. :smt023 Can you provide links to the product and prices?
Postby Mike_H » Fri 03.07.2009, 02:08
(83.69 KiB) Downloaded 30 times
Mike_H
Postby Elanlover » Fri 03.07.2009, 02:47
Thanks, I've seen these recently and bookmarked them. They looked pretty good, almost identical to the Elise lights and less money. More options too. Probably a better buy than the Elise lights. Are ballasts or any other gear needed to complete the install?
Postby Ade » Fri 03.07.2009, 23:04
Hi,
The fitting of the lights depends if the hole as been cut out to take elise lights. If it as then a back panel as to be made to fit the light to, if not it can be cut out to suit these lights. I had to make a back panel which was,nt to difficult. I can tell you how to make the panel if needs be.
Ade.
Ade
Users browsing this forum: Bing [Bot] and 1 guest
