Leaking oil cooler
Leaking oil cooler
Postby vin111 » Tue 19.02.2008, 20:23
hi guys, Im just wondering if any one knows where I could obtain a oil cooler from,
just had mine serviced and found its leaking, iv been quoted about £600 any one know any other place that is cheaper, many thanks Vince
vin111
Postby Monty » Tue 19.02.2008, 22:09
You could always try SW Lotus :?
Postby RayD » Tue 19.02.2008, 22:31
Or look into having it repaired at Serk Radiator Specialist (Serk Marston)
Ray
RayD
Postby paza1 » Tue 19.02.2008, 22:59
Are you sure it's the cooler and not the pipes to/from it?
Mark
Silver 1992 SE Turbo.
paza1
Postby Dave Eds » Tue 19.02.2008, 23:16
could just be the washers in the banjo connector thingys. :wink:
£500 at either Stoneleigh or Donington for a new cooler last year. :cry:
Postby stevieshag » Wed 20.02.2008, 10:56
vin111
you have pm
stevie
black lotus elan se (kermit)
Mitsibushi outlander
suzuki gsx 750 W (Gonzo)
stevieshag
oil cooler
Postby michaelfrench » Tue 18.03.2008, 12:10
mine was leaking earlier this year about 2 inch diameter wide puddle every day of oil for a few weeks.got quoted 600 + vat for supply and fit of new cooler, but its stopped leaking now. should i ignore it now?
michaelfrench
Postby rip » Tue 18.03.2008, 13:01
Had mine changed recently. It was weeping very slowly until GST Performance cleaned the engine bay when replacing the head gasket recently. It turned out that the oil cooler was virtually being bandaged by the oil which had weeped out and turned to sludge.
Michael, yours could possibly be 'bandaged' by its own sludge too.
You may only really find the leak by giving the cooler & pipes a good cleaning. You may also find that doing this means you need to change it sooner rather than later.
The good news is that SJ's do a replacement cooler for £165. It is the same size as the genuine Lotus one, but uses slightly different connectors. Gerald was quite used to fitting these though. :D
Postby michaelfrench » Wed 19.03.2008, 15:14
ok thanks for that. could you give me their phone number?
michaelfrench
Postby WillB » Wed 19.03.2008, 16:40
WillB
Postby RichyP » Wed 19.03.2008, 17:05
Just helped AndyH change his oil cooler last week. Used the SJ sports car one. Surprisingly easy diy job even with the air con pipes in that area.
Toughest bit was getting the wheel arch liner off! The connectors are different in that there's an additional bolt on the 'cooler inlet and outlet orifice but the banjo bolts go straight into this no problem.
We had to get additional 4No. M6 nuts and bolts as the nuts were captive on the old 'cooler mountings.
easy job!!
RichyP
Postby Gazza » Thu 10.04.2008, 11:48
I'm thinking of getting an Aluminium oil cooler made to replace mine.
Anyone think of a reason not to do this or should I just go down the SJ (£192) route.
Thanks, Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby M100 TWO » Mon 14.04.2008, 09:44
why is the oil contaminated that has run through the cooler, or do you have some surface corrosion and think it might leak in the future
diff
M100 TWO
Postby Gazza » Mon 14.04.2008, 15:32
It is very possible that it is leaking, but won't know for sure until it's removed.
Just want to know if making an oil cooler in Aluminium is a good idea or not, material wise.
Thanks, Gary
SOLD
Gazza
Postby M100 TWO » Mon 14.04.2008, 16:27
Gary I would have thought the majority made are of an aluminium alloy
M100 TWO
Postby Gazza » Mon 14.04.2008, 16:38
Cheers John
SOLD
Gazza
Postby muley » Tue 15.04.2008, 07:49
Gazza wrote:John
Thanks, Gary
Gary,
Save your money - the heat transfer rate wouldn't be much different.
Now, the intercooler on the other hand ...
Postby Gazza » Tue 15.04.2008, 09:26
My parts list for HGF is huge already, can't afford more.
Only going to get the oil cooler made if needed. Option are new Lotus one for £500 odd, SJ for £190 or get one made up in Aluminium.
Gazza
SOLD
Gazza
Postby DeeAitch » Sun 20.04.2008, 14:29
Took the wheel arch liner off to investigate a bolt dimension and found a leaky cooler :evil:
Anyone know the thread size for the Banjo bolts? Also the pitch dimension between the 2 connections would come in handy :P
DeeAitch
Postby M100 TWO » Sun 20.04.2008, 18:01
the banjo bolts will be OK, it is the two washers either side that will be the problem, they have a rubber insert in the metal washer to seal the banjo
diff
M100 TWO
