it appears that the list is corrupt.....well it got messed up in the last couple of posts.....heres what I think it should say
A - Wastegate Stud Set (WSS) £20
B* - Cam Cover Centre Cover (CCCC) £6
C* - CAS cover and internal brackets (CAS) £6
D* - Oil Separator cover (OS) £6
E - Peco rear hanger (PECO1) £1.50
F* - Turbo compressor housing (COMP1) £7.50
G* - Heatshield retaining bolts (HSB) £TBD
H - Pre-cat Stud Set (PSS) £TBD
I - Exhaust Stud Set (ESS) £TBD
Y - Exterior door lever A bolts and washers (ABW) £....
Z - Full Clam Fixing Kit (FrClam) £....
1. Paza1 - B*,D*
2. Paul.P - A,C*,D*,E
3. Ailwyn - The works
4. Ailwyn - The works
5. Pinky - B*,D*
6. Surferphil - A,B,C,D,Y,Z
7. Surferphil - A,B,C,D,Z
8. theelanman - A,B*,C*,D*,G*
9. Woody - A,B*,C*,D*,E,F ,G,Y
10. Gazza - A,C*,D*
11. Dico - C*,D*
12. Nige - A,B*,C*,D*,F*,G*,Z
13. Nobby - A,B*,C*,D*
14 The Ref- B*C*D*F*
15. Benmac - A,B*,C*,D*,F*,G*,Y
16. Davidjt - B*,D*
my mod and woodys mod seem to have been dropped but I think this list should solve it.....
You can use the saving for some Loctite
