several questions in one topic
Postby L.G. » Wed 12.03.2008, 22:16
Hi all,
I have a couple of things I wanna ask, any help is greatly appreciated.
1) My front bumper needs adjustment. Do I need to tell anything special about this job to the garage I'll take it to. Is there a helpful part in the manual?
2) One of my backlights needs adjustment as well. It is left side; it has gone inside on the corner side and out on the other (the side next to the number plate) Is this a "rear bumper out job" or "the plastic light covers in the boot out job"?
3) Yesterday I did some stop and go traffic. I stalled the car twice (novice :lol: ); when you restart it, it starts very quickly but it doesn't rise to idle speed. It hovers at about 500 rpm, when you push the accelerator a little it first doesn't respond but then picks up, rpm rises and you're on your way. If you leave it on it's own in a situation like this it becomes normal in 3-4 seconds. Is this normal? May some parts need cleaning?
4) Last question: My turbo kicks in at about 2000 rpm. :-D I can't remember if it does 0.6 bar at 2000 rpm but it definitely comes into action. I am actually very happy with it, but does this indicate somethings wrong? Wastegate maybe? By the way, at the top end turbo works no problem and doesn't overboost.
Thanks for reading,
L.G.
'95 S2 driver #286
L.G.
Postby Specky » Wed 12.03.2008, 22:34
internal cover remove and adjust.... or file a bigger slot for the locating studs..
Users browsing this forum: AhrefsBot and 0 guests
