nearside constant velocity joint gaiter split . MOT failuire
Drivetrain problems
Postby rushing » Mon 07.04.2008, 11:13
Hi again- another problem
Can some one please tell what this is ??? " nearside front constant velocity joint gaiter split " this is what it says on the MOT certificate . The machanic said there is a split in the front offside / drivers side CV joint. he said i need to get the replacement part for that. Now!! i dont have a clue about this ??? . Any suggestions and is there a part number for this?? . Where can i get a new cv joint if this is split please . Can i also use non lotus parts at General motors .
please advise
many thanks
rushing
Postby Monty » Mon 07.04.2008, 11:40
If thats what it`s failed on then you do not need to change the CV joint, just the rubber gaiter and repack with grease. You should be able to get a universal one gaiter from your local motor factors and you just cut down to size.
Postby rip » Mon 07.04.2008, 11:59
It's a common MOT failure for FWD cars. The rubber gaiter is there to stop the joint drying out or getting dirty & wearing (which is exactly what will happen if you leave it too long).
Proper part is probably GM & will most likely involve removing the wheel& hub.
Like Monty suggests, a Universal one is probably the easiest fix.
Postby Enright » Mon 07.04.2008, 12:05
Putting "split AND gaiter" into the search function gives about 3 results, one of which is a link to this page:
http://www.lotuselancentral.com/repair/splitboot.htm
cv joint
Postby rushing » Mon 07.04.2008, 12:26
this is why i like this forum . Everyone is so helpful and always gives a speedy and correct advise to the novice . Thank you all i appreciate your comments
rushing
Postby M100 TWO » Mon 07.04.2008, 13:12
look under Dura boot it will save striping right down
diff
M100 TWO
Postby addict » Fri 18.04.2008, 12:28
have a look in the wikilec i did one last week and did a write up
addict
Postby Sy V » Fri 18.04.2008, 13:21
Enright wrote:Putting "split AND gaiter" into the search function gives about 3 results, one of which is a link to this page:
And this write-up's by me, so it's f**king good!
LEC Godfather
Postby Enright » Fri 18.04.2008, 13:34
addict wrote:...did a wright up
:shock:
That's the sort of thing that can seriously make my eyes water.
