How to reset your ECU?
Postby joop » Tue 15.04.2008, 09:16
Anyone know how to reset your ECU?
Any tools require?
joop
Postby Enright » Tue 15.04.2008, 09:31
A 10mm spanner (or is it 11mm?) to undo the battery clamp positive terminal.
Alternatively you can just unplug the multiplugs from the ECU itself, but this isn't the recommended method (however most of us do it that way).
Postby andyhaworth » Tue 15.04.2008, 09:49
Enright wrote:A 10mm spanner .
13 on mine, but the same end result :)
andyhaworth
Postby L.G. » Tue 15.04.2008, 11:27
13 on my mine as well.
'95 S2 driver #286
L.G.
Postby paulwatkins » Tue 15.04.2008, 12:25
No tools required for me, just a quarter turn :lol:
paulwatkins
Postby M100 TWO » Tue 15.04.2008, 16:40
Joop you can shorten the re learns for some of its settings in the engine management system by steady cruising in 4th gear at 40 MPH
diff
M100 TWO
Postby M100 TWO » Tue 15.04.2008, 16:45
Paul it looks like you don't have a small fuse link for the radio and powering the ECU when removing the disconnect for security reasons
diff
M100 TWO
Postby Enright » Tue 15.04.2008, 18:41
M100 TWO wrote:Joop you can shorten the re learns for some of its settings in the engine management system by steady cruising in 4th gear at 40 MPH
diff
Now not being able to remember the difference between 11 and 13mm is one thing, but I really don't understand that at all! Am I going senile? :?
M100 TWO wrote:Paul it looks like you don't have a small fuse link for the radio and powering the ECU when removing the disconnect for security reasons
diff
I'm not sure what advantage bypassing your cut-off would offer either - apart from not having to keep re-programming the radio.
Please enlighten me, because I think I've completely missed the point on both of the above - sorry! :bonk:
Postby paulwatkins » Tue 15.04.2008, 20:01
diff
I dont use the switch for security, just for isolation purposes when carrying out any works.
But your right, when I power back up I do have to re-tune the radio each time. It's not a difficult job though; I just have to press the AT button once. But i'd rather the switch isolated ALL the electrics in the car when doing any works (which it does :-D )
paulwatkins
Postby Gary » Tue 15.04.2008, 21:25
and presumably it is to stop the battery discharging during periods of non-use, which means you want to disconnect everything !
Postby GeoffSmith » Tue 15.04.2008, 22:54
Enright wrote:... but I really don't understand that at all! Am I going senile? :?
I remember reading something along those lines a long time ago (but can't think where so it would be useful to be reminded and stick it in the Wiki). I guess it's to do with the ECU re-learning the key engine parameters but it may only apply to closed loop.
Postby M100 TWO » Tue 15.04.2008, 22:57
Neil the first is self explanatory, the second if for security reasons you remove the screw to disconnect the battery, but, have a link with a small fuse all the systems stay powered up eg. alarm, radio ecu but if some one tries to hot wire the car, the load from the starter would blow the small fuse and result in a dead power supply to the whole car
M100 TWO
