esp88
- Tinkerer
by Dave Eds » Fri 02.05.2008, 14:50
Hey Yasou it's good to see the pics
How's your daughter like the new car?
by esp88 » Fri 02.05.2008, 19:34
Hi Dave
Well, as you know she love the Elan but it took some time to agreed the insulance becase of her age ! (1.1K a year ), So it cost me a lot this year !
The last week was Espirt needed MOT (replaced rear dampers etc..)
Any way the car running fine and still cosmetic some issue !
Buy the way, Does any one useing "Snap off" steering ?
Y.Hotta
esp88
- Tinkerer
by GeoffSmith » Fri 02.05.2008, 19:40
Looking good Yasou. Don't be afraid to drop in more often, you'll find we're generally more sophisticated and refined than the LEF crowd.
- Kitty Fiddler
by theelanman » Fri 02.05.2008, 19:53
nice pics Yasuo
how did the wishbones go
cheers
G
by Nige » Fri 02.05.2008, 20:47
Welcome to LEC and I hope you enjoy your Elan. I like the carbon Fibre inserts in the doors and that's an interesting steering wheel.
Back in Blighty
Nige
- LEC Administrator
by theelanman » Fri 02.05.2008, 20:53
by esp88 » Sat 03.05.2008, 21:03
Well, today started replace St. brakehoses and I noticed very badly rost rear wishbones
, so end up with replacing the rear wishbones !
It's not hard work but take a time and thanks for theelanman !
the St. rear wishbones which I bought from theenlanman fit very nicely !
Y.Hotta
esp88
- Tinkerer
by theelanman » Sat 03.05.2008, 23:51
yasuo
dont forget to note where the front inboard cam bolts are positioned....
it saves hours of trying to line up you rear end tracking
cheers
gareth
by XiPHiAS » Mon 05.05.2008, 23:59
Welcom ...
I like what you did to your Elan, exept of the steering wheels and shifter.
XiPHiAS
by Doug » Tue 06.05.2008, 06:19
nice pictures and car!
how about some exterior pictures? is that Steel Grey I see??
- LEC Founder
by theelanman » Tue 06.05.2008, 08:21
by esp88 » Tue 06.05.2008, 19:27
Changed wishbones done !
also replaced brake pipe and the brake master cylinder !
Replaceing the Master cylinder was not easy job becase there are almost no space (need small hand) !
The color code Grey-blue ?
the Elan has been ownd by elan1 few years ago !
Next issue will be 4 new tires and the door seals......
Y.Hotta
esp88
- Tinkerer
by Paul.P » Tue 06.05.2008, 19:54
esp88 wrote: The color code Grey-blue ?
Ah yes, i remember the car, didn't it need a respray on the bonnet, if i remember right ? , but it was a nice car
by Doug » Wed 07.05.2008, 02:10
Doh! You got me
- LEC Founder
by XiPHiAS » Wed 07.05.2008, 15:11
your interior is so nice ...
Where did u find those white diales?
XiPHiAS
by theelanman » Wed 07.05.2008, 15:39
lockwood
theyve been quite popular...they also do them in other colours too....
by XiPHiAS » Wed 07.05.2008, 16:00
theelanman wrote:lockwood
Can u be more specific please?
And can i open the cluster and replace the original or do i need glue parts?
XiPHiAS
by theelanman » Wed 07.05.2008, 16:33
I'll find the lockwood site for you alter as Im at work at the mo....
however it is just a change out the dial back grounds.....
take out the gauges from the car....take off the existing fronts and replace with the white and replace.......
well that the simplified overview
they are about
£40 IIRC ......Paul P on here worked with lockwood to get them done
by esp88 » Sun 01.06.2008, 20:27
Two more mod on Elan last month!
Well, I got good price 4 tires Pirelli Zero Nero 205/40 17' with
new wheels (Opel Corasa C type) offset 45.
Also mounted Snap off steering wheel !
esp88
- Tinkerer
